MOOTS
MX6000
Jun 27, 2019
2,188
2,713
Canton, Georgia
No experience with tractors, but I personally would not be surprised to see that on a first oil change.
Oh I’m not surprised, just wish it would have been done at the actual 50hrs, or close and not 127, when I did it today. I bought the tractor last Saturday with 125 on it.
5,205
People wash their tractors? That's like washing a hammer. I bought it new too, I'll have to try it sometime. Never occurred to me, though I am a stickler for keeping it inside when not in use, and I always flip up the seat if I'm out of it for more than a few minutes.
Got started on cutting and chipping the dead fall from last winter, the Honda Rancher ATV and trailer for the chips will then haul and spread them on my path I have thru the trees on the left that runs along a stream with a 14% grade, so a lot of white water.
It just occurred to me, I have never washed my ATV either, also bought new, but like the tractor it's always under cover and is otherwise very well pampered, I guess i think a little dust and dirt or mud won't hurt anything? View attachment 60353
I have a truck like that. Bought it new. Generally pretty nice to it. My wife washed it once. I don’t know why.
woodsy
95 Kubota L3300DT W/FEL, 60" AgroTrend 3pt snow blower89 Arctic Cat 440 Panther
Apr 20, 2021
132
60
Maine
Spread and "float" back dragged 9 yds of 3/4" crushed gravel over the 11 yds of 1 1/2" gravel that I spread on the driveway last week. Long driveway.
The 1st spread was a little rough because I wasn't familiar with the float feature (FEL newb) but got that figured out because I read about it here and wow looking pretty smooth now. Probably been 15 yrs since it had been worked on so needed quite a bit
of building back up to crown it.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
650
648
Indiana
Did the 50 hour maintenance items today. Also lubed the FEL points.
Noted that there are no zerk fittings on the rear lift top link, contrary to the owners manual.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
This landscaping endeavor is sure racking up some hours on the tractor. I had to grease the FEL again yesterday.
I definitely learned one thing though - my greasing abilities are on par with my sheetrocking expertise.
ie for every gallon of compound I put on a wall, I sand off 1-1/2 gallons worth. For every tube of grease I use on the tractor I'm removing 1-1/2 tubes worth of overflow.
pokey1416
Jun 24, 2020
567
844
SW Michigan
Reworked landscape gonna use the boulders we took out of river.
Before and after. Probably gonna use washed river rock for infill.
2C739013-1434-4C17-B258-9520AE3B0B01.jpeg 27B2EC0E-6DD9-4D94-A752-8FC72A27AB2F.jpeg 23997D6A-0A17-4BA9-9E0E-FBBCA7723461.jpeg
Reactions: 8 users
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
335
554
NH/VT NEK
Some of my larger projects are waiting on the tooth bar for the bucket......but until then it is small stuff.
One of the larger projects is reworking the drainage ditch along the 500'+ driveway but today I gathered some small "boulders" of 18=24" diameter and replaced the rotting hay bales and stakes used by the building crew to slow the water down during heavy rains and spring runoff. Heck of a lot easier than without the tractor.
This morning,,,,,,unloaded 6bags of stone for the pad under the new heat pump for the basement finishing.. Yup, worlds most expensive wheelbarrow ......but I know 98% of you would have done the same thing. Why walk 40lb bags of rock around the house and down a hill when you can drive them all at once.......lol
5,205
Definitely agree on the wheelbarrow comment. For materials like that I’ve been heading to the store with an empty pallet in the back of my truck. Load it on the pallet at the store and use the tractor to fork it off the truck and then to wherever it’s needed. I’m not moving it by hand any more than I really need to.
Reactions: 6 users
nbryan
Jan 3, 2019
1,336
866
Hadashville, Manitoba, Canada
I assume your 3-point top link is adjustable. And there's no zerk on its adjusting sleeve? Should be one there, and on the right adjustable lift arm, too.
MX6000
MX6000 Cab, Wicked Grapple, Box Blade, Forks, Rotary Cutter, Rake, Tiller, etc.
May 15, 2020
21
36
Colfax, N.C.
Installed Rear Remotes and Fit-Rite T-n-T Cylinders. Not a bad job, about a 3 hour installation, no leaks and appears to work flawlessly. Now to get it in the field...
Reactions: 11 users
ken erickson
Nov 21, 2010
1,294
2,269
Waupaca Wisconsin
Beautiful equipment and shop!
DaveFromMi
L3901 RCR1260
Apr 14, 2021
650
648
Indiana
There is one on the RH lift arm, a couple of plugs where the zerks should be on the top link.
Will try to install a couple of zerks on the top link.
B737
LX3310
Jun 9, 2019
2,022
2,205
had an absolute ball today brush cutting a retention basin. The RCR1548 is a beast!
could not have been a better set up. No trash, No stumps. just growth, lots of growth.
Reactions: 11 users
SAR Tracker
Nov 17, 2020
246
364
Central Oregon
So, there's a song by the Sandals called "6-pack" that I have on a USB stick in the stereo on my LX2610. Started the engine this morning, and was letting it warm a little. Suddenly, this song comes on, with "pssst - pssst - pssst - pssst - pssst - pssst". I panicked, thinking Oh Crap - I've got a big hydraulic leak somewhere, and then the rest of the song started. I looked around, just to make sure that no one was watching!
9,480
I have shop and cab envy! Very clean installation with good hose routing.
9,480
Awesome! I have the RCR1884 which is also a beast and really enjoy cutting the field. Kind of wish I had some tall stuff to cut down like you though. I have a trip coming up but when I get back I'm hoping to help out a friend with a very big field and very tall grass. It'll be fun as long as I don't run over a faun.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,467
2,043
WestTn/NoMs
I almost got one last year. Really shook me up. He ran over to the edge of the field and layed back down. The grass wasn't very heavy. I think I mistook him for a fireant mound.
802Driver
LX2610SU 60" Bucket Land Pride54" Box Blade Farm King 4572 Rear Blade
May 18, 2020
122
91
Manitoba, Canada
I was out preparing our septic field for topsoil yesterday with the box blade, turned out rather well.:)
Reactions: 7 users
