random
Nov 2, 2020
716
401
NC
A couple days ago, I got the thing running again thanks to advice from you guys here!
Now I have wires that need to be reconnected :) Looks like that's this weekend's project.
johnjk
Apr 13, 2017
1,695
1,893
West Mansfield, OH
Did the final mow this afternoon on the B1700.
CEJOHIO
L2501 LA525 and Land plane rear blade
Aug 15, 2020
Tractor5102
Took delivery of L2501. 2200 ft driveway to maintain. Rear blade made quick work of some high spots
johnjk
Apr 13, 2017
1,695
1,893
West Mansfield, OH
Ended up going after another maple across the trails. Too muddy to haul out but after 4 hrs with a chainsaw. I’m beat. Nice haul though for the day. Probably another 7 bucket loads to get that maple
Bmyers
May 27, 2019
3,496
4,430
Southern Illinois
We finished replacing the water pump on my dad's MF 383. Used the Kubota to help get the loader lined back up and on his tractor.
Dad is a happy camper now that his loader tractor is back up and running.
random
Nov 2, 2020
716
401
NC
Nothing big today, just moved some leaves around for a burn pile, then moved some tools around. Load the bucket & drive around is a lot easier than hauling them all over multiple trips...
gmbc
B2650HSDC ,bucket, Forks, Front Snow blower, MMM, Tiller, Land Rake
Mar 11, 2016
104
30
Warman, Saskatchewan, Canada
Installed new LED lights in place of factory front lights on my B2650 with cab . Lights up above wsheild. Cleaned and waxed. Next service for winter. Now just admire when in garage 😃👍
shelkol
bx-2200, Woods BH6000 backhoe, Tach-N-Go quick attach bucket, snow blower
Nov 12, 2015
211
186
Westford, Massachusetts
shelkol.com
BX-2200; Replaced the two hydraulic hoses that went to the steering cylinder. (Last year replaced the two hoses from the transaxle to the steering control and put in a new transaxle fan) While working on that found a broken wire to a sensor on the right side of the engine and fixed that. Then realized it's time to replace some battery cables. Well it is a 2000 or 2001 so I guess I can't complain.
I had also picked up the aftermarket boots for the tie rods. They went on easily and seem to be a real nice product.
UpNorthMI
May 12, 2020
849
567
Up North, MI
It was an amazing day in Northern Michigan yesterday, temps were up in the mid to high 60's. It was a great oppertunity to cut a bunch of tree trunks that I had stacked. My Kubota excavator helped to lift the trunks from the pile and then to hold them at waist height while I bucked them with my big 28" Stihl chainsaw, my L3901 towed out the log splitter and then helped me load and transport split logs to fill my truck and utility trailer, a full day of hard work but we will have amazing outdoor fires all through the winter. Just did not seem like November with deer hunting gun season opening next weekend! Equipment sure makes those jobs a little easier. It took a few hours this morning with a wheelbarrow at home to unload, move and stack that wood, must bring a tractor home next time to get ready for the winter, snow pusher and snow blower.
pokey1416
Jun 24, 2020
568
855
SW Michigan
Had jobs lined up today. Mostly pushing up burn piles but did have one where I had to drag a fallen tree across the creek. The BH92 with thumb had no trouble at all. Bonus, got my bucket clean from the water! These temps in Michigan are unbelievable, coming to an end. Taking BH off tomorrow and prepping for the s...word.
BXHoosier
BX24
Jan 21, 2018
497
591
Indiana
Used the loader to install my new garage heater today. Had to get creative to lift it high enough. Will be nice to have heat out there this winter. The old heater wasn’t vented so it wasn’t safe to run it. Carbon Monoxide is no joke. That, and burning propane puts out a lot of moisture which made everything rust. I had it tied down with ratchet straps before this pic was taken.
drewzee87t
L45 TLB, B2910 Turbo
May 20, 2016
176
misery
I fixed the leaky oil cooler return line at my HST filter today and put on new seatbelts.
I got the Kubota o-rings and just drained the mid pto plug (about 2.5-3 gal). Pulled the filter and filter housing in order to get the lines off. Replaced two o-rings on the return line and on the line that goes from the filter to the charge pump? I think that's it. The old o-rings didn't appear to have a problem.
Cleaned everything up and put back with new o-rings. Ran it for awhile and no leaks. Ran it with neutral range and with the GO pedal pushed to run the pump. No leaks. Loaded up the brakes and pump in Medium range for a while. Backed it up and went forward in limited space a bunch of times. Let run some more. No leaks. I will drive it tomorrow in light and when it's not parked in for the night :)
While I was there I put in the new belts. The clasp/release belt wouldn't grab. I had to replace them in my last one too. Check your belts they might not even work. hah. $20 closeout at seatbeltsplus.com fits perfect.
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
Drilled some holes and mixed/poured some concrete.
I can't pour directly into the tube without spilling some because the tube is not wide enough. I am going to get a plastic "big foot" to use as a funnel in the future and that should allow pouring into the form without spilling any.
aaluck
Oct 9, 2019
984
836
Snowdoun, AL
I installed a "tiltmeter" I purchased from the TBN site store. Not a bad price and I really need something I can gauge how far I am leaning over, my property is hilly and a lot of uneven areas. I usually try to go up and down rather than across, but sometimes you just can't.
I realize this is an old post but where did you get that model? I cannot seem to find one similar and like the design.
bird dogger
Vendor Member
Feb 24, 2019
1,720
1,670
North Dakota
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,440
1,733
Kalamazoo, MI
I removed the operators platform from my M5660 to take down to the local Rhino Liner dealer to have it sprayed. Wasn't too bad of a job. The Rhino dealer wanted $350 to spray it in place because they would have to do a lot of masking off areas of the tractor. I opted to put in some sweat equity and take it off myself then haul it down there and see if they'll use it to clean their gun out after doing someones truck bed for a C-note or hopefully less.
Will post update when I get it back.
