motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
42
Atascadero
I have a DRAW Bar on my 3 point that has a 2" trailer ball. I use my tractor for pulling out and parking my flat bed and dump trailers. Moved the flat bed today.
Fluke631
B2650
Oct 29, 2019
70
Ordered some valve assy on amazon. Cant see or touch my tractor until I return from deployment in May !!!
Bmyers
May 27, 2019
3,496
4,430
Southern Illinois
Did some more cleaning at the farm
Here is me supervising the work
7,076
Wow Bmyers, productive!
As I'm set up for snowblowing, I did NOTHING with my little BX. Sits there with the battery tender.....
I hope it stays that way until spring....:D
SidecarFlip
Banned
562
Started both my M's up this morning and let them warm up for 30 minutes or so. They are both sleeping in the barn all winter.
dlsmith
BX2230, LA211
Nov 15, 2018
1,302
919
Goshen, IN
I bought a new cutting edge for my BX a few weeks ago, and decided to add a replaceable cutting edge to the bottom of it. Bought a 48" long one from the local Kubota dealer, I think it was for a later BX or B model, with 7 holes to bolt it to the bucket.
I figured the weld-on cutting edge would be really hard and difficult to drill, but after I located, marked and center punched the 7 mounting holes, and set it up in the drill press. I started with a 1/4" cobalt bit and use lots of lube, and it drilled just about like mild steel. I finished up the holes with a 1/2" cobalt bit, used plenty more lube and it took hardly any pressure to drill them out and the bit was only warm when I finished up.
Now I'm trying to decide if I want to tackle replacing the cutting edge myself or take it to the local Amish welding shop. As reasonable as their prices are, I'm leaning towards taking it over to them.
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
9
Columbia, CT
I needed to attach Quick Hitch bushings to my new blade today. Used to hammer the roll pin in on older attachments. Decided to use my little 12 ton press to save my fingers from the hammer! Worked great...
dlsmith
BX2230, LA211
Nov 15, 2018
1,302
919
Goshen, IN
Sorry. The picture is inverted and I can't seem to flip it.
Sent from my SM-G930W8 using Tapatalk
Assuming you took it with your phone, go into Gallery or whatever app to view the pictures and select that picture. Touch the screen and a row of icons should appear at the top right corner. One of them should be three dots in a vertical row, touch that and a menu should pop up with the choice to rotate the image left or right 90°. Rotate it 180° either direction and you should be ready to go.
Normally, on an android phone when you take a picture in landscape mode with the phone with it's right side facing up, the pictures will be properly oriented.
