Magicman
Oct 8, 2019
6,057
9,533
Brookhaven, MS
knotholesawmill.com
Thank You. Every forum seems to be a bit different but uploading directly from the HD is very user friendly. Anyway I did use the FEL to bring up some firewood even if it may be December before it is used. :)
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Dug Up A Stump....leveling a buddy's front yard this week.
tiktock
225
Plaistow
Had a 90 year old massive oak that split over a road and had to be removed. I kept everything for firewood. Used the little BX to move tens of thousands of pounds of wood that I'll split come spring. Some were so big they hardly fit in the bucket and I had to use the bucket hooks to retain. I'm not a farm guy and live residential and this was a 100% un-doable job without a tractor. The large rounds probably weigh 300#.
Only got through about 1/3 of it today. Bringing a friend to complete it as I physically cant even budge some of the rounds once I get them out of the FEL.
lunasdude
Kubota BX1880, FEL, quick con pto, box bld, land plane, flail mower
Dec 22, 2018
55
Los Lunas, NM USA
Wow, since I bought my little monster (BX1880) I have done so much, but this weekend I used my 4ft land plane to do road (private road) maintenance, fix the neighbours driveway entrance after a heavy rain and fix my driveway.
Still can't believe after 18 months of ownership how much I have been able to do!
:eek:
dlsmith
BX2230, LA211
Nov 15, 2018
1,302
919
Goshen, IN
Wow, you even have an orange chain!
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
That is a big tree... Amazing what a scut and loader can do saving back breaking labor.
I helped a neighbor with a similar sized pine a few weeks ago, and the loader and pallet forks made it a much easier job.
michigander
547
234
Northern Michigan
Those rounds are huge !!! Those huge ones look like a splitting maul would half/quarter them on site then move em. :)
tiktock
225
Plaistow
I would’ve tried to cut a few slabs out of that oak.
I ended up with one nice 3" round slab that is in good condition crack-wise but as you went up the trunk even 8" up from the stump the center crack was almost the entire way across.
It would have been nice to get some actual board slabs out of it but I dont have the access/machinery myself.
Oliver
L2501, JD 3520
Feb 2, 2011
540
129
Preston County, WV
Nice work cleaning up that tree and putting the wood to use, and thank goodness for your tractor!
I had a large border cherry fall over about that size a few years ago, and of course it fell on my side! I ended up cutting part of the trunk in (4) sections around 5' long each then ripping them in half for benches which I put around the property.
Gave one to a friend who sanded it down then varnished it and has it inside her house, damn if it didn't come out nice.
tiktock
225
Plaistow
UHG that would have been a great idea and so easy if I had asked the company to leave a few longer!
Oliver
L2501, JD 3520
Feb 2, 2011
540
129
Preston County, WV
I can say it wasn't easy ripping through 5' of cherry. I had a freshly sharpened chain, still for each split I had to stop a few times to let the chain (and me :D) cool down. Oak is harder yet, I only did two benches from a large oak around 10 years ago. Before that I made a bunch from pine which ripped fairly easy.
tiktock
225
Plaistow
That makes me feel a bit better. I dont cut Oak often and I had to cut down a few of these logs and it took more effort than I thought it should. The pros seemed to have just the right saws/chains/skills to make it look easy.
Magicman
Oct 8, 2019
6,057
9,533
Brookhaven, MS
knotholesawmill.com
Don't overlook the fact that you can Google search for a portable sawmill that can saw lumber or live edge slabs from downed trees. The sawing rate might surprise you.
I am kinda sorta retired but portable sawmilling is my part time job.
2,430
There are “special” ripping chains that cut much better and faster than normal crosscut chain. You get a fairly smooth surface using a milling attachment. I think my milling attachment is a granberg mini mill.
Oliver
L2501, JD 3520
Feb 2, 2011
540
129
Preston County, WV
I was wondering if they made rip chains? Makes sense they would just like any other saw, if I ever make these again I'll order one.
A funny story about these benches. I first made a few after taking some pine down and had a couple along the edge of the pond. This was before I got the knack of notching the "V" in each base just right and some of those benches could rotate unless one sat down somewhere in the middle. Well one day the mother-in-law was over walking around the pond, plopped down on a bench just sitting on the front edge, the top rotated forwards dumping the poor woman on her butt at the pond edge with her feet in the water. :D
michigander
547
234
Northern Michigan
Hour meter is at 47.8 hrs. so looking at what to do for 10w-30 oil change.
Looking at what Mobil has for full synthetic diesel oil.
I'm not worried about winter starting tractor sits in heated garage.
