Buck3343
24
US
Finally removed the Backhoe and installed my boxblade on old Beulah!!!!
Sent from my SAMSUNG-SM-G891A using Tapatalk
Tooljunkie
May 13, 2014
4,150
Moved boats around for storage, 26 foot pontoon boats are no match for the L1501!! Glad its all flat around here.
My three point trailer hitch and forks rock!
Pallets for everything makes moving stuff easy.
JimmytheGeek
B7200E
Mar 12, 2016
21
Franklin, KY
Mowed about three acres at the house we just moved out of, after finding the right deck belt in four tries. Now I've got to find hay equipment to use with my B7200E...
Sent from my LG-H900 using Tapatalk
7,072
Removed a raised bed so the house can be re-sided.
7,072
Then took loader off and mowed vacant place across the road.
Rguzman
Kubota M8200
Oct 3, 2016
Pasadena, TX
Worked on a new driveway. Gave grade, spread dirt, and am currently preparing for rebar and concrete( 120 ft by 20 ft) worked my kubota hard even though i need to repair loader cilynders.
Builtough
Kubota B2601 with loader, pallet forks, rear bade, bush hog
May 15, 2015
38
Ottawa, Ohio, United states
Great weather here in Ohio! I hooked up the bush hog and went into the woods to make some trails. Combination of the piranha toothbar and the bush hog made my 2601 a formidable trail blazer! On casualty was a flashing light. We'll see if all the tires are still holding air in the morning
Alexisferos
L-1501 DT
Oct 24, 2013
245
Greece
in my village now we are three Kubota power tractors.
:D:D:D
i took i fast shot today, sorry for the dark bat is night here,
from right to left, L1501DT (L185DT) , L2000DT(L225DT) , L245DT,
We are going to open a Kubota fun club. :D:D:D:D
RedDirtSurviving
Kubota B7200
Oct 29, 2016
Denison, TX
Today I started tearing the hydraulics apart. I took the rear controller apart, cleaned it. Took feed lines off to check the screen, didn't find a screen. Next is to pull the pump and replace seals to keep hydraulic fluid form getting into the crankcase I guess. Didn't think that could happen. Hopefully once all this is done I can actually do some work with the thing.
7,072
Had a house project get messy. Did start some yard restoration.
BCrouse
196
PA
I moved a pile of well drillings (millings?) for my neighbor and put them behind some of my targets. Its finely ground granite, its like sand only heavier....
7,072
Had a house project get messy. Did started some yard restoration...
Did mean to say we're getting there, though.
BruceP
G5200H
Aug 7, 2016
852
373
Richmond, Vermont, USA
G5200 garden tractor with 600cc 3-cylinder
The owners-manual suggests regular cooling-system flush-n-clean using Kubota cooling-system cleaner.
1) drained coolant from radiator and engine, remove lower hose.
2) used garden-hose to flush both engine and radiator thoroughly.
3) Replace lower hose, filled with water and radiator-cleaner.
4) Mowed leaves for several hours.
5) Drained (lots of black crud came out)
6) Fill with distilled water, run for 10 minutes, allow to cool, drain.
-- Repeated rinse 4 times
7) Filled with 50/50 mix
Interesting note: For each 'rinse cycle', after the drains stopped flowing, I used leaf-blower into radiator-opening and got a lot more water out of the drains.
