I was able to pull the rear tires off and decided to pick up a new pair instead of dealing with tubes or anything like that.  I'm going to clean up the wheels, grind everything smooth and hit them with a nice coat of primer then Kubota Orange from TSC.   They should look like brand new when I'm done.
I picked up tubes to put in the front tires. I plan to pull them next, clean the rims up and give them a new coat of paint then put everything back together.
Not sure what I'm going to do about the hood, it's pretty beat up but a replacement would cost about $250 more than I paid for the whole tractor.
I put a brand new Interstate battery on her and replaced the main battery cables with some custom cables I made.
Once I replaced the battery cables, installed the new battery and spent about 30 minutes cleaning up old wiring connectors I hit the key, warmed the glow plugs and she fired up like she was fresh off the showroom floor. I let it run for about 30 minutes to get everything nice and warm, I found a small hydraulic leak at a low pressure hose fitting that shouldn't be hard to fix. I also found that the previous owner installed a simple push button momentary switch because the main key switch failed or something like that. The button is rusted and won't move so I had to kill it manually. I picked up a new switch today to fix that problem.
