What causes this?
billrigsby
Mar 17, 2015
1,003
146
Florissant CO USA 8213'
www.facebook.com
Curious what causes this in a post, I see it from time to time......
I***8217;m wondering if someone has any reliable sources to research engine fitment. I***8217;d like to compare dimensions between different engine models including rear flywheel mounting configuration and bell housing mounting dimensions.
I***8217;m considering an engine swap on my B7100 and I***8217;ve seen multiple times that the only options are 750, 850, and 950. My intention is to find exact specs and determine why that is. If I want to choose an engine other than one of those, I need to know exactly what mods will need to be made in order to do the swap.
Engines I***8217;m strongly considering are 905 or 1105.
Thanks in advance.
3,248
it's the code used for an apostrophe. I believe it only comes up when people are using taptalk.
SidecarFlip
Banned
548
That is correct and in as much as I don't use it, you won't see it in any of my posts.
5,174
Thanks in advance.
There are many variables to why a D650, D750, D850, D950 will work and others will not.
Flywheel and bell housing mounting is the least of your concerns, but will be most likely different.
Clutch plate alignment is an issue, as even something like 1/8" difference and the clutch plate will not release.
Oil pan is the number one concern as most will not clear the front propeller shaft.
Some other major issues are the hydraulic pump drive.
The water pump and fan drive (most stick out further)
The charging system
Oil filter placement.
And that's just a few of the issues.
