Welder Mechanic/Machinist home brewed tools
5,687
Ray's welding thread got me to thinking about different projects.
Every once in a while there is something that requires "outside the box" solutions. While working on a L2050 I had installed the water pump and realized I had missed a bolt. I ended up making a tool to reach it. Cut off a box end wrench and welded it to a screwdriver. Even then I had to grind down the OD of the box end to reach in the area.
Last week I noticed a leaking fluid on the L4240. It was hyd. oil from the cooler up front of the radiator. The line comes down a couple of inches and turns for a couple of inches then curves again and is clamped onto tubing going back.
No room for anything in there. It took a while to figure what size head, if it had one, on the wire clamp. Finally looked an another clamp and realized it was a 10mm. I could not get a 1/4" drive ratchet with a socket in there. So I finally took a 10mm socket and welded it to a rod to reach up in there and get it tight. It was loose about two full turns!
I think during assembly the clamp is installed, then later it's in an awkward position to reach.
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
Re: Home made tools
Harbor freight wrenches are good for something lol. I’ve got a selection of modified tools at work as well. With a torch and a welder you can get a wrench to fit almost anywhere. Have quite a few that have been heated and bent to fit and a couple that have been cut in half and welded at 90 degrees, works great for getting to the front cab mount nuts on the super duty’s that like to spin.
redfernclan
155
Sweet home, Oregon
Re: Home made tools
Been turning wrenches for over 30 years and I can't tell you how many "custom" made tools I have made. Thin wall box end wrenches, stubby wrenches, spanner sockets made from brazing key stock to the outside of a socket. The best times were working at a saw mill. The manager believed in having the steel and tools on hand to get what needed done done so when we would be rebuilding a hyd cylinder and needed a 10 inch spanner wrench, you go cut one out of 1 inch plate, grind the corners off, custom fit it for the cyl and set it aside for next time. Learned a lot of fabrication skills there.
5,426
Home made tools
All I can think is "Necessity is the mother of invention."
The ingenuity you guys have never ceases to amaze me! :)
I've modified a few tools.. usually accidentally, and not in a good way!:eek:
Honestly, have done a couple intentionally after seeing examples here. Like fordtech said, HF wrenches are handy for something!
I've been working on the 'Moline lately. It's still at my folks due to a governor problem. Replaced the governor and she runs much better, but linkage is a little wonky with the replacement governor. Common for them.
Since it's an hour away, it's tough to get exact measurements/geometry.. .just the stock governor rod seems "a little" too long ....
I made an adjustable-length/geometry linkage that should work.... I hope... Also, have a couple "extra" ends I made of different lengths to provide more versatility/alternatives.
I know I was inspired by you guys to try to make something that might work. 1/4" rod was $3 for 3 feet...
OEM governor rod, on left. My adaptation on right...
