Weather/Water proof switch box
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
I have Googled it with no luck :(
Does anybody know if and where I can get a 4-5 place weather proof switch box and switches that isn't huge? I want to be able to mount it on my BX24 somewhere. I want it so I can control the extra lighting I want to add.
While we are on the topic of switching....Does anyone know where the flasher/turn signal unit is located on a BX24?
dhanames
2012 BX25
Oct 5, 2012
10
Torbay, Newfoundland, Canada
For the BX25, I used a trailer wiring box and drilled it for micros switches that can be purchased on Ebay. All switch connections are in the box. This operates 2 forward LED floods, 2 rearward LED floods and a flashing strobe light.
The box did have a rubber seal but I didn't trust it and added some of my own silicone sealing.
6,629
You can get weather/water resistant boxes at Home depot or Lowes, they come in both aluminum and plastic.
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
A standard household outdoor box ( the grey cast alum ones) with a blank cover plate could work. Drill the cover for toggles and hide the wires behind the gasketed cover.
They make little boots to add extra protection to toggle switches.
Sent from my DROID RAZR using Tapatalk 2
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
Nothing is waterproof. Once moisture gets in, it can't get out, corrosion and failure will soon follow.
Everything you are working with is low-volt and should remain open.
Someone here in just the last week made a very nice switch plate near the rear fender.......look around for it.
cabu
Kuno B1-15 (B1502DT)
May 24, 2009
736
Germany, Oyten
"Everything you are working with is low-volt and should remain open."
The voltage we are talking about is only 12V. So there is no electrical hazzard for you, as long you do not lay you tongue over it :D The only problem is corrosion and you can prevent that when you put some grease inside the switch. The only things that do waterproof switching is something like a reed-relais with a magnet or an induction switch with a piece of metal. The rest is just covered with rubber and sooner or later you get moisture inside that start the corrosion.
Another solution could also be: By a bunch of cheap switches make them easily replaceable and change them every few years...
ebay has some marine switches: http://www.ebay.com/bhp/waterproof-switch
I like those with light:
http://www.ebay.com/bhp/12v-waterproof-switch
You could just drill some holes in a bracket and fix that switchboard to your friend. :cool:
Have fun
carl
