Water Pump Questions
Junkman302
B7200HSTD
May 8, 2025
NC
The cooling fan is wobbly with lots of play in the water pump pulley, and coolant is leaking through the weep hole on my B7200. It needs a water pump.
I can replace the defective pump with a genuine Kubota water pump for around $250 from Messicks, Colemans, etc. Pricey.
I can replace the defective pump with a no-name aftermarket water pump for around $50 from Amazon, Ebay, etc. Much less costly, but I'm concerned about the quality (or lack thereof) of these pumps.
Or I can repair/rebuild the defective pump with a genuine Kubota bearing/shaft and seal from Messicks, Colemans, etc. for about 75 bucks. Doing this doesn't look to be any different from water pumps I've repaired before. Just need a decent hydraulic press and some extra time.
Any additional thoughts on which repair might be the most desirable?
2,863
So ......... it boils down to $50 , and a huge MAYBE - or $75 and you know how to do and will know if correctly done- but it will require some time.
I vote for the $75 way!
Hoserman
Aug 1, 2022
209
333
Grayling, MI.
Junkman I do believe you just answered your own question. OEM parts= fix. Alternative aftermarket parts= dangit! Your choice, but I would go OEM all day long. Been there done that.
Donystoy
Dec 10, 2013
673
306
Binbrook, Ontario
I agree with the $75 fix. I replaced the pump on my original B7200 some years ago but used a genuine Kubota part. Parts seemed to be a lot more reasonably priced back then. I replaced the hydraulic pump in 2014 for under $500 and it was going for over $1300 about six years later. One reason I converted my new BH77 hoe to a self-contained off the shelf pto pump so as not to add wear to the tractor pump.
