Warn me against this money pit B7100
Tranberg
20
Copenhagen, Denmark
There's another one with less implements for twice the price ($4600) nearer to me, but further away from my brother's place, where the tractor would be used, and where there's room to take it apart and restore it.
By the looks in the ad, it's not twice as good.
But I must say that this process is making be realize how expensive even the tiniest spare parts are, since the market is tiny, and these things costed 10 times as much when they were new.
BX23S-1
540
201
No where Special
There`s gotta be something better out there to buy. I myself would walk away from this one. Or anything as old as it is. Finding crucial parts will likely be a problem, and very expensive.
Your title says it all; "warn me against". You`ve been warned.
torch
Jun 10, 2016
2,650
889
Muskoka, Ont.
Air filter is missing! That's a big red flag for me. (Besides ingesting dirt, it suggests that someone was using starter spray to try and get it going).
Too bad. It does have the optional high-output alternator to support all those lights.
Tranberg
20
Copenhagen, Denmark
4 years later, and on a whim with rosy tinted foggy glasses, I just bought a worse rust bucket B7100D (4WD gear) for 15,000 DKK equivalent to 2,150 USD
It starts right up, sounds right, and all the gears on the main lever works.
Range lever and front assist levers broken off at the transmission.
I took the transmission cover off, and the gears look good, and I could move the range gears back and forth with a screwdriver.
No brakes, and the clutch pedal and both brake pedals move in unison.
Generator replaced with a cobbled up plate with an elbow for the coolant hose and a conventional car alternator hanging off the side.
3-point lift inoperative (lever broken/missing) and 6 feet of hydraulic hose attached to the diverter valve, and a similar return line.
A chain-drive drop-down for front facing PTO
Many wheel bolts missing and the rear hubs are both welded to the axle shafts.
The once installed cab has been chopped off at dash height, the dash is not original, but could be part of the cab that once was.
The wiring is a mess.
The air filter cover is rusted out beyond repair.
The list goes on.
  • Sad
5,099
The list goes on.
Seems as though you are now worse off than before !!!!
8,098
The list goes on.
So far nothing you've said sounds unworkable.
trial and error
Feb 16, 2023
394
386
NY
Good luck, you've got your work cut out for you but these are generally easy to work on, finding parts that's gonna be the hard part
5,522
Heck if YOU don't spend YOUR money now, on a few 'projects', you'll just leave it to your children and THEY will spend YOUR money on THEIR 'projects'.....
