Voltage test
al m
Kubota b1750,60" mm,48" argo trend snowblower,5' grader blade
Jul 30, 2012
258
smiths falls on Canada
I installed a new Dynamo on my b6100 on the weekend.tonight I did a voltage test at the battery posts.before start up,12.4 v.Start tractor,rev engine,13.4 v
My instincts are telling me all is well
Searching this board gives results for amperage
Can anyone confirm my belief the electrical system is working correctly?
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
Increase in voltage says the dynamo and rectifier/regulator are working to some extent, and could be totally fine. Hopefully with some time the terminal voltage will increase a bit higher as the battery charges.
2,190
13.4 is about perfect - too much higher can cause problems, lower is not getting enough.:)
Should have a smidge more than 12.4 before turning the key however. 12.6 would be 100% charged;)
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
13.8~14.1 volts when cold would be better for a cyclic starter battery, as components heat up the voltage will generally fall a bit. The output of dynamos is generally low so until your battery's storage capacity has been replenished from it's previous state you may not see the higher terminal voltages.
al m
Jul 30, 2012
258
I am seeing this ,along with my initial positive thoughts,that the changing system is fixed and operating as it should
Thanks guys
Tooljunkie
May 13, 2014
4,150
27
Actually a good like new battery is 13.2 volts. 2.2 per cell when new off the factory line.
Rule of thumb in automotive field is 14.2 to 14.6 volts.
Minimum should be 1 volt over battery voltage. I would say with a dynamo you are right on the mark.
2,190
TJ,
For a typical LEAD-ACID battery, you will never find a "fresh" battery at 13 volts! It might have started there, but will never "finish" there:):)
Here is the chart for "typical" fresh batteries :
State of Charge
Specific Gravity Voltage
12V
100% 1.265 12.7
75% 1.225 12.4
50% 1.190 12.2
25% 1.155 12.0
Discharged 1.120 11.9
now this is a wet cell (flooded) battery...most common on the market.
A hydrometer will tell the specific charge if a VOM is not available.
Now when you charge it - it will climb up to the voltage close to the charging voltage (and yes that rule of thumb is true +1 V) - but will settle back down to the 100% charged voltage.
Excellent reading on state of charge and charging of L/A batteries.
https://pssurvival.com/PS/Batteries/Lead_Acid/Lead-Acid_Battery_State_Of_Charge_Vs_Voltage_1993.pdf
