Vevor Products
11,757
Vevor sells their products around the world and some areas do require filters due to fuel supply conditions I was told.
I can see that. There are some places in the US too where extra filters might be a good idea. šŸ˜‚ I wonder what the filtration specs are on the Kubota fuel filters. I don't remember seeing a micron rating on the box or on the filter itself but that might just be my bad memory. My boat has a 10 micron fuel filter and water separator between the fuel tank and the engine, in addition to another fuel filter on the Yamaha engine itself.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
418
315
NH
I am thinking of getting a Vevor pump. It does have a filter, if it needs it or not, depending on the options of many, it doesn't matter - it's there.
The features I like about it are the auto shutoff nozzle and that the suction is a 14-37" telescoping metal pipe, not plastic, which I'm thinking may be more durable.
I realize it is not Fill-Rite quality but would like some inputs on the pump itself, not the tank of filter. I could buy a cheaper pump for half the price, but not sure I want to go that cheap.
I do not use much fuel mainly in the winter, depending on how much snow we get.
Caden
1979 B7100
Apr 16, 2026
268
144
I'm late to the party here but I have a Vevor story of my own.
At work we have some lift magnets of various sizes and brands. Maybe 4 Vevors out of 12 magnets. I was assigned one time to create a test procedure that aligned with ASME standards to check that the magnets were all still capable meeting the standards.
Every Vevor magnet I tested failed. Most couldn't pick up 1/3 of their rating, much less exceed it x3 like the standards required. (at the time anyway). All the others, regardless of age passed easily. If you were to find that out by dropping a sheet of steel, that would have ended badly.
So I don't think I'd ever buy a Vevor product myself, regardless of what it was.
7,296
My $275 GPI EZ8 just died after 4 years of very light use. For one of those four it was basiclly idle and GPI seems to have a reputation for premature failures. I will not buy another so its either even more money for a Fill-Rite or $188 for a 15 GPM Vevor with auto shutoff. I am not struggling with the decision.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,465
656
Richmond, Virginia
Vevor.. hit or miss on quality. Cheap cost, sometimes you get a good deal, sometimes you get what you paid for. Just keep your expectations realistic.,
Fuel filtration. Kind of a no-brainer. Excess filtration is 100X better than inadequate. An extra filter between the dinosaurs and the combustion chamber is no big deal. Replace a filter when the flow rate drops. Not rocket science and not something to loose sleep over.
The station i buy my fuel from, has a canister filer as it exits the pump into the hose. My fueling rig has a water/particulate filter after the pump and before the hose. My machines have one or two filters., If this over kill keeps me from having a fueling issue a mile from my shop,it is money well spent.
William1
Jul 28, 2015
1,465
656
Richmond, Virginia
And herein lies the problem. Many things are carry-overs from a time when things were different, or simply not an apples to apples comparison. Storage tank material, internal coatings, fuel quality, fuel chemistry, the precision/requirements of the internal components of fuel systems, onboard filtration etc., have changed drastically over the years but the anachronisms linger.
If you want a fun topic to investigate, do a search on the whole theory about water getting into storage tanks or fuel tanks. Read some of the studies done on this and do some math and calculate the maximum amount of water vapor that's even possible in an empty 200 gallon tank let alone one that's 1/4, 1/2 or 3/4 full. There is so much mythology it's ridiculous. If you have water in your fuel storage tank it's not coming from air in the tank. This is why I've never subscribed to the theory that you should keep your fuel tanks close to full to avoid condensation. It's simply a myth that isn't supported by the math or physics.
I've removed the cap on my tractor and several times, found perhaps a quarter teaspoon of condensation in it. That's just the fill cap and what I saw that day. No telling own many drops had formed and dripped in to the tank..
Humidity here is such that puddles form even after a month of no rain.
Moisture/humidity and gasoline has not been a problem, just diesel.
William1
Jul 28, 2015
1,465
656
Richmond, Virginia
I recently got a wall mount retracting extension cord.16 Ba wire, 15 am integral breaker, a led to show powered. Un-spools nice, easily retracts, no need top 'feed it'. Swings/pivots good. Easy mount (a separate bracket gets attached to the wall/ceiling then the 're-tractor' slides in and a screw retains it. Seems pretty good.
Vevor 'Hit N Mss', you never know.
BAP
Dec 31, 2012
3,182
1,300
That's the point I was trying to get across. These transfer tanks are intended to be transported to a commercial fuel/service/gas station. Filling up a transfer tank should be no different than filling up a car or truck, unless you figure you're going to cut up a concrete block in the bed of your truck while the tank is filling! I've never seen someone at a gas/diesel station run the fuel through a 30 micron filtration system before they put it into the tank of their vehicle.
The reason you don’t see it is that the filters are inside the pumps. Most every state has requirements for what micron filters must be installed on the pumps for their state.
Grimor
2002 BX2200 with loader, mid mower deck
Sep 1, 2024
26
26
Chicago-ish
Vevor is great. Low prices and mediocre quality. you'll know pretty quickly if the item will work or not. 9/10 times they will refund the purchase and not ask for the item back. Their 3 point quick-hitch with the receiver doesn't work with their weight box, and the receiver is too small for a standard hitch.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,934
2,435
WestTn/NoMs
Just be aware that 16 ga SO cord coiled on a reel should probably be limited to something like 10 amps. I wouldn't leave it untended with a heavy load on it.
Yes, there's always one and this time it is I :).
William1
Jul 28, 2015
1,465
656
Richmond, Virginia
I actually checked, it is 12 gauge, not 16 and has a 15 amp reset-able breaker integral, plenty for the shop vac and miter saw.
Any device with a heavy load, gets its' own outlet right at the device (like a window A/C or fridge/stove/compressor,/ect.)
