First post here. I know its not a tractor, but its a kubota diesel generator which probably has some similarities in general to operations. I have a V2203DI kubota with a variable 50/60hz generator. When working correctly, they run at 50hz (1500rpm) in low load operator and 60hz (1800rpm) in high load. One of the ones I'm working on starts up at 60hz no matter what. It has a voltage controller that provides a signal to the electronic governor. Normally if one of those is bad, it will run at 50hz no matter, so I know thats not the issue (switched it out just to make sure). There is an engine speed sensor that sends signal to the the EG, checked the pins on that into the EG and they have continuity, also replaced the speed sensor just to verify its working correctly, still starts up at 60hz. Switched out the EG with one from a unit that is working correctly, same problem exist.
One thing I do not quite understand is how these electronic governors work with the speed sensor and the mechanical injection pump. How do they get the signal and regulate the fuel on the injection pump? I haven't taken out these injection pumps before to look at the internal mechanical governor (fuel solenoid too). Maybe somebody could help me explain how these work as I figured most basic diesel generators work close to the same. I'm guessing that the mechanical governor or pump has an issue? Any help would be greatly appreciated.
