V1305 Injector Pump Rebuild Tappet Shim order?
hoosierwoodguy
B2710
Sep 1, 2024
Indiana
Hello! A careless mistake for sure, however, I inadvertently shuffled the order of the tappet rollers and shims during a rebuild. They each have a number on the bottom of the shim which I understand denotes their thickness (07, 07, 10, 12). In which order do they go?
shims and wonder if anyone can help me with their correct placement?
ruger1980
L4310 w/La682, L225
Oct 25, 2020
512
199
CNY
This is an adjustment that would need to be done on an injection pump test stand. They don't go in any particular order. The followers, shims and plunger barrel assemblies are matched to provide equally spaced injection events.
There may be a process to make these adjustments measuring the height of the plunger in comparison to the barrel or specifically the fill port in the barrel but I do not have that procedure.
8,831
You will need to send it to a fuel injection shop and have it rebuilt!
