Used anti-freeze source?
2,679
I recently picked up an old yard roller/road compactor. (sorry, keep forgetting to take pics) Very old school, thinnest material is 5/16" steel, 61 1/2" wide, weighs 335lbs empty, should be 911lbs full. It's pretty rusty, approximately 60 years old, & my place in the mountains occasionally gets down to -15 degrees F. I would like to fill it with something that won't freeze or rust, so I thought I would get used anti-freeze from various garages, oil change places etc..
I thought they would be anxious to get rid of old anti-freeze, but was shocked to find most places dump used anti- freeze into their used oil tanks. A few places keep it separate, but would not let me have (or buy) any because of liability. I need about 70gals of liquid, and would prefer to not have to take out a second mortgage to pay to fill a yard roller. Any ideas?
3,523
If you can find a junk/auto salvage yard you might be able t pick some up after telling him what you need it for,, if not like Murph said fill it in the spring and dump it in the fall
6,993
Fill it with sand almost to the top then use a 50/50 mix of water and antifreeze just to top it off. I weighs more than strait antifreeze and is a heck of a lot cheaper.;)
You can use strait dry sand only too.
2,679
Yeah, fill with water, use, drain for winter
Trouble is, I want to use it from now until probably early to mid December, depending on the first major snow that sticks.
Interesting, I'll have to check into that suggestion, thanks.
gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
Jan 5, 2013
257
47
Sandpoint ID
www.gemstarcustoms.com
Not sure about where yer at, but up here the Dump/Land Fill we have a separate section for automotive waste products.. There are Gallons of used antifreeze just sitting there.. Keep in mind that you will have to test the mix for where the ratio is at..
I like the idea of the sand, way less chance of a leak
2,679
Around here, (Phoenix, AZ area) lots of cities have hazardous materials turn in days for such things as anti-freeze..... but it is impossible to get anything from them, I've tried.
As for sand, wet or dry, the fill port is a brass male garden hose fitting, with maybe a 5/8" hole..... kind tough to get any quantity in or out..... maybe I can weld in a larger port of some kind.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Here's a completly left field thought. Go to Wal-mart or somewhere cheap and buy a electric heating blanket like you would for a bed and wrap the roller in it and plug it up on High. Naturally you'd have to keep the roller dry from rain/water but I don't see why it wont work.
6,993
Hey put a block heater in it and then you'll have a hot roller! :eek: HAHAHA
Just weld in a 4" pipe plug or bung out of a 55 gal drum.
Home depot has test plugs (rubber stoppers) for holes up to 4" holes too.;)
2,679
I have a magnetic block heater that I haven't been able to use for the tractor, (can't access any place on the engine to stick it) maybe I should use that. Only one minor problem- no power yet in the garage. Guess I better get busy digging that power line trench! Hopefully the power doesn't go off for long periods up there. Keep the ideas coming!
On an impractical (ridiculous?) note, a neighbor suggested filling it with lead shot or BBs. Even if I could afford that, I doubt I could move it! Maybe with my F350 6.0L.....
3,523
Lil Foot if you find that much lead shot laying around cheap please,,, please,,,, please,,,, let me know I ll come pick it up!!!:D
2,679
Yeah, I know the feeling!
ipz2222
L235, bx2670
May 30, 2009
1,927
32
38
chickamauga ga usa
Used antifreeze is what i have in my roller and 3ph weight. I took a gas water heater and shortened it to fit between my lift arms and put sand and used anti freeze in it. Just added some more today. Sorry you're not close, I have about 30 gallons.
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
My Grandpa had a gang of rollers that were probably 24" diameter pipe and 6 or so feet long, filled solid with concrete. Do you think you'll really need to unload it in the future?
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
This is where the landscaper in me gets real technical and ponders why in sam hell you'd want to roll a lawn? Its kind of counter productive from aeration which is suggested to be done twice a year on a lawn.
Packing it down or unpacking...
2,679
Actually, I don't want to roll a lawn, I don't even have a lawn. I want it for compacting a road bed that I'll be modifying soon. I learned early on that if I call it a road roller, everyone assumes it's one of those two rollered, self propelled things for compacting asphalt paving.
2,679
I'm not sure, but I'd like to keep that option open for now..... empty, I can wrestle it around & even load it on a trailer by myself.
BadDog
B7100D TL and B2150D TLB
Jun 5, 2013
579
Phoenix, AZ
Aren't they used mostly for either rolling in fresh laid sod, or for going over top-coat when reseeding to bring the top-coat/soil into firm contact with the new seed.
