Up Front or At the End, You'll Pay
Gene Blister
2019 Kubota B2601, FAL LA435, Snow Blower BX2822A, Land Pride rear blade RB1572
Aug 4, 2019
84
20
Cocolalla, Idaho
“The man who picks up a cat by the tail will get ten times the information of the man who just reads about it.” –Mark Twain
So, the reason shear bolts have a notch, then that smooth, unthreaded section below the head is, after they’ve sheared off, you can get the broken section out of the connecting holes; they pretty much fall right out of my snowblower auger. Change out time: 30 seconds per bolt.
So, when you want to save a few bucks and use regular, fully threaded grade 5 bolts from the CoOp, you’ll spend many hours trying to find the almost invisible remaining section, which is smoothed off and fused into the holes by those very same threads. Then comes the pounding with a punch, the slipping, the bleeding…
So what’s next? Am I looking at drilling out the bolt butt to clear the hole? Alone. In the snow. But hey, I saved almost 15 cents per bolt!
200mph
Mar 3, 2017
1,228
60
PA
Do you realize some snowblowers require standard grade 5 bolts withOUT any machining detail?
For those that require special bolts, I agree.
Sodark
2018 B2650 HST ROPS, BH77 Backhoe
May 15, 2018
171
Pacific Northwest US
Having recently spent the weekend trying to remove a busted bolt from an engine block, my advice to you is to drink until you lose memories from your childhood and go organize your garage.
3,961
Removing broken bolt methods can generate more posts than buying a Kubota BX tractor! I have had the most luck using left handed twist drills and a lot of patience. :D
5,322
Gene,
No drilling should be required, you just need to get a really bright light and a good set of eyes, get the sheared bolt lined up with the hole and use a drift punch to drive out the stuck section.
In fact drilling it could cause you some serious damage to either the collar or the shaft.
If you can't get it, send me a PM and I'll come over and help ya out, I've had to deal with quite a few of those! ;)
Gene Blister
Aug 4, 2019
84
20
Cocolalla, Idaho
Gene,
Thank you for the offer, Wolfman. I may just have to take you up on it. I'd like to meet over coffee, anyhow.
The primary problem is, as you said, lining up the hole in the auger with the bolt, then securing said free-wheeling auger so I can get a punch awailing away.
Today being a dry day and all the other responsibilities taken care of, Im going to bring the wife out in the cold, glove her up, get maybe vice grips or some other type of clamp to serve as a handle and have her keep things lined up while Im working the punch.
I brute force doesnt work Ill try, in order, Dusty Rustys suggestion, then Sodarks.
Dismith, the cursing and hurling of tools goes without saying.
Ill keep you posted.
4,155
Since all the shear pins I have are 1/4-20, I modified a punch to be just smaller in diameter than 1/4" , shank about 3" long with a 'shallow' centering point. Once I line up auger and shaft, put point intothe 'hole' and 2-3 hits ,the old pieces are out. Between the shallow point and good fit , the punch doesn't jump out,so you CAN whack it good especially the all important first hit.
3,961
If you keep your augers well greased, no need for brute force, since the broken piece of the shear pin will be well lubricated and come out with a gentle tap. You can also paint it with never seize before installation.
Gene Blister
Aug 4, 2019
84
20
Cocolalla, Idaho
Ok, the drama has played out with ultimate success.
Bright LED flashlight, check. PB Blaster spray lubricant to wash the impacted ice out of the hole, check. Womping punch and small hammer, check. Moving the PTO from mid- to rear-drive so I could rotate the shaft to a more workable position, check.
Three gentle womps and the emergent tip of the offending bolt showed me I was on target. Several more energetic womps and the problem flew out against the maw of the blower and was trashed with extreme prejudice.
Auger oiled and greased per the manual, all new bolts to be dosed with Permatex Anti Seize and Im blowing sweet and pretty as Bleeding Gums Murphy channeling John Coltrane.
Thanks everybody! Im gonna take Sodarks suggestion, now, and leave the past behind.
Until the next bonehead mistake!
5,322
Excellent! And just in time, big snow to hit tomorrow night! ;)
whitetiger
Nov 20, 2011
2,619
1,134
Kansas City, KS
Now that you have the shear bolts replaced, take a centerpunch or chisel and make a set of timing marks so next time you know when it is lined up. :)
3,961
Please explain how you can accomplish this? :confused: The auger already has a hole where the pin goes in the auger, and there is no way that any markings will show up on the drive shaft, since it is inside the auger shaft.
Cglaza
L2500DT, BX2380, G6200H
Aug 30, 2015
170
Freeland, mi
You would move the auger so that you see half the hole showing through and take a narrow chisel and make a mark above and below the inner shaft. May need to use a file to make sure the hole is still round but will help you find the broken piece easier next time.
Sent from my moto z4 using Tapatalk
whitetiger
Nov 20, 2011
2,619
1,134
Kansas City, KS
I was thinking he was talking about the impeller shear bolt rather than an auger shear bolt. Auger holes can be lined back up by looking at the position of the shear bolt in the opposite auger.
The impeller bolt is the one that I always get to replace for customers after they maim themselves.
Cglaza
Aug 30, 2015
170
Freeland, mi
Same principle only harder to do.
whitetiger
Nov 20, 2011
2,619
1,134
Kansas City, KS
I probably do a dozen or so a year. That is why I mark them as the owner has usually tried to remove the broken piece without the holes lined up.
Cglaza
Aug 30, 2015
170
Freeland, mi
I think marking them is a great idea. Definitely a time saver
3,101
First of all, I”m so smart I don’t have to own a snowblower so I don’t have to deal with this issue. (I live down Sou’f where we’uns let skool out when we’uns git a eench of snow...). But on my other equipment I’ve had success in simply driving the old pin out with the new bolt.... which is then in-place and only needs the nut. YMMV
