Unable to start
Mister6shot
G1900
Apr 24, 2026
Marshall Michigan
When trying to start there is no sound from starter. I have replaced the battery and starter dash lights dim when turning key but still no sounds (engagement of starter). What could else should be checked? Yes I have pedal depressed and I’m sitting on seat
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,049
1,044
E.
go through std stuff like:
- battery strength
- grounds clean and tight
- pto lever disengaged and safety switch functioning
- speed control lever in neutral position and safety switch functioning
- the fusable link under the oil filter is ok but given dash power should be fine
- the brake pedal should have a safety switch in that model make sure its working. same as seat safety switch making continuity correctly
- do all the steps in section 8 troubleshooting steps of the operators manual
- check the 10a-15a-20a fuses for continuity
would be where i would start
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,880
2,293
Western MT
Try bench testing the starter just in case it is binding or some other safety switch is engaged.
10,544
Have the battery load tested.
If that's good jump the solenoid and see if the starter will crank it.
