Turbo
pigdoc
G1800S L2500
Aug 19, 2022
417
361
SE Pennsylvania
I know this is an old thread, but I was bored so I was surfing Service and Maintenance.
I've been driving a 1st generation Cummins for 16 years now. First generation motors are not intercooled. The Bosch VE pump in my truck is mildly tuned, running 4" exhaust, and a bit more boost than stock. I can't give you many specifics, because my son specified it and put it together.
Anyway, about a month ago, I was doing some hauling in the mountains of WV, just south of Morgantown. Land of the 5-mile, 5% grades. Near the top of one of those grades, she overheated, because she had blown out all the coolant. [That's another story.] Melted a piston. #5 or #6, I can't quite tell. #5 is more susceptible, because it's not on the end of the block. Still runs OK, but has a helluva piston slap until the engine warms up. Pushing some oil out the breather. Tailgate being automatically conserved while I drive. So, motor is due for replacement,...soon (anybody have a junkyard short block to sell me?). But, still, I've put 1000 miles on it, since that incident!
Bottom line: air gets hot when you compress it, and when you pour more fuel and boost into the mix, you're creating a situation not unlike one of those old hand-cranked coal forges. The faster you spin the handle, the hotter it gets.
The smaller Kubota 3-cylinders already have a reputation for struggling to keep up with the heat the naturally aspirated motor generates! And, remember, the 1st gen Cummins was DESIGNED for turbocharging! The engineers detuned the nuts out of theses engines to control warranty claims. Bone stock, they're rated at only 160hp, but 1000hp (at the rear wheels, on a dyno) is well within reach without any work to the bottom end. Just because you can doesn't make it a Good Idea, despite the 'gee whiz' factor.
By the way, many years ago, my son did the same thing with his 900hp 1st gen, boosted to 60 lbs, on a 1 mile, 3% grade. That's when he added an intercooler and an exhaust temp gauge.
Live and learn,
-Paul
thebash1
b2023
Jan 24, 2023
sedro woolley wa
Dumb question time. Has anyone tried to put a turbo on a BX2360?
Not dumb, lots of bobcats have the same motor with turbo and jacobsen mowers. Usually the d1105 I put a kit together for less than 500 got 35 hp as the bobcat motors spec at. ebay. Need more fuel to get more hp. fuel shims, plunger, hidden screw. Snowmobile universal turbo on smaller. bobcat turbo best.
Rdrcr
Vendor Member
May 7, 2021
780
982
WA
The L2501 is one of the few that kind of make sense to turbocharge.
Totally agree! ;)
Mike
5,188
I am no turbo expert - but giving that 23 HP engine a turbo would be like giving a prostitute a 2 carat diamond ring!:ROFLMAO:
Even if you could tune the injector pump, I think it would only gain a HP or two.
But hell - I would love to see it work!
There is a guy on the y'tube that stuck a kubota tractor engine with a turbo in a little ford ranger and made it work.
I have a lovely 2+ carat solitaire diamond ring that I have been hanging onto for 25+ years.
I paid a good bit back then, and thought I had a use for it,.....but didn't.
At 82 don't quite know what to do with it now.
I think it has some serious value.
Maybe a grandson?
