Tube cracked on LA240
Rob28791
Bx25
Apr 27, 2026
NC
I recently bought a little BX25 and after about a half hour I was moving the belly mower with the bucket and heard a disheartening clunk. The cross tube on the loader had a previous repair that I didn't see. It split all the way around the repair. What would be the best way to approach this repair? Is there a repair collar or a jig to weld it back up?
lynnmor
B2601-1
May 3, 2021
1,817
1,621
Red Lion
I would consider replacing the entire tube, that metal has been fatigued too much.
5,523
+1,000
No way I would trust that tube now.
And normally I refrain from critiquing peoples welding skills, cause I ain't the best….but I gotta just say WOW, those are some ugly welds in that first pic……. :eek:
Caden
1979 B7100
Apr 16, 2026
314
181
Agree with @lynnmor about the entire tube replacement.
Cutting the weld all the way around the pipe to reuse the flanges for the cylinder pin could be tough. Might be easier to replace that as well.
Wonder if you could get a thicker wall pipe to prevent that in the future?
11,757
The cross tube looks to be bent towards the bucket so my guess is that curling the bucket with heavy loads has caused the fatigue failure over time. Break out ratings are quite a bit higher than lift ratings but I have no idea if the loader is designed for infinite life if used properly. For steel, if the stress is kept below 50% of the yield stress you can expect infinite life.
Vlach7
L47 305DT JD500C
Dec 16, 2021
452
329
Frazier Park Ca
If you were handy with metal, and you had enough play to be able to slide a tight fitting thick wall interior pipe on that and then beef up the outside obviously better than what you bought it with that would also be a consideration, assuming nothing is fed through the inside of that tube.
whatsupdoc
L3302
Jul 9, 2024
178
204
Replacing that tube is a easy job for a welder. Trying to repair
that mess is just not wise.
