Tsc tractor hydraulic oil
yamachuck
l 1501
Jan 28, 2017
cleveland ohio us
Hello everyone. I had to buy hydraulic oil to' flush my l 1501 transmission. Tech had this oil for 25 bucks a 5. I'm sure it's good to flush the system. Would you trust it to use for a final fill. Any info from experience would be appreceiated thanks
sagor
Jan 9, 2017
287
65
Sudbury, ON, Canada
Hard to read that last bottom line on the back. Says something about 1974 or older. Then says something about newer tractors (after 1974) should use a "Super S Premium" oil instead. Key word there is "Premium"
May be ok for flushing, but I would worry about using it permanently in any newer tractor.
redmaher
253
US
From my experience it is a good flush fluid. However it is thinner than the newer fluids. It will not harm or cause leaks but being thinner it will find small leaks that the thicker fluids won't.
Sent from my LG-H901 using Tapatalk
clay45
L2050DT, TSC 5ft Rake, Tartar 5ft rototiller, TSC Middlebuster, TSC CarryAll
Feb 6, 2015
279
SC
I used it in a little Yanmar I had without incident. If your tractor will accept 303 specs it should do well.
ThisIsNotaStep
2005 bx23 tlb
Nov 26, 2010
133
Ontario, Canada
Yes. the walmart brand is compatible, says suitable replacement for UDT right on the label. I've used it the last 3 or 4 years in my BX. Not as good as the UDT but app 75 % of the cost ($50 a pail)
8,051
Look a Mystik JT-5 it's a lot better than Walmart fluid. ;)
