Truck ramp,deck and tailgate
Tooljunkie
May 13, 2014
4,150
27
Photos of just completed ramp and deck for loading snowmobiles and atv's.
I was building them at my previous job,now they want more. First of three i have to do. My new welder is working great. IMG_2879.jpg
Will put up another photo next post.
Tailgate accepts ramp,well secured.
Angled back so atv's will fit with gate closed and can see through it when backing up.
Tooljunkie
May 13, 2014
4,150
27
Tailgate and ramp IMG_2877.jpg ramp clips on tailgate and wont slip off. All the pieces are manageable. The driver of this truck is a female conservation officer and wont use any other loading system.
4,626
Nice!!!! I like it. :D I use a set of aluminum bifold ramps that utilize tie down straps to lock it to the tailgate.
Tooljunkie
May 13, 2014
4,150
27
Try and drag a moose up any other ramp, it becomes a challenge. Some of them have winch mounts for dragging things on, so its handy in so many ways.
2,855
I shoot a moose or an elk its gettin quartered and skined and in the back of a side by side or inthe bottom of the boat,,, But then I dont plan of shooting either of them critters,, I dont even plan on shooting a deer any more,if I cant get it inthe game bag I just aint gona shoot,,,lol :D
Nice looking set up I would like to see how it is used
Tooljunkie
May 13, 2014
4,150
27
The mooses loaded are either roadkill or illegally hunted. Same for bear caribou or what have you.
Next one will be different,cant remove tailgate due to backup camera and rental agency wants it to renain with truck. But it being aluminnium i need to come up an adapter that will carry ramp and preserve gate. That dont weigh 1000 lbs and wont clip off fingers if used improperly.
They had 3 piece gates in the 90's that caused some serious injuries. I have one of them,salvaged from the scrap pile.
2,855
Im still trying to figure out how a little slip of a gal is gona get an 1100 pound moose in the back of a pick up truck :D
Tooljunkie
May 13, 2014
4,150
27
Winch. It mounts to"headache rack" usually side mounted and a sheave to run cable out rear of truck. Reason for side mount is recovery of objects in ditch or on roadside.
2,855
Interesting,,very interesting,, indeed,, have you any idea of the load rating of the rack and how it is mounted to the bed? I am asking for a reason, maybe load fire wood in 8 foot lengths, in a pick up bed or on to a trailer.. Always get ideas from you guys :D
Tooljunkie
May 13, 2014
4,150
27
All i can say is a 700 lb plus snowmobile doesent bother it. Its 5 cross pieces,1x2 .125 wall at cab on vertical,2 1x1 .125 wall in middle and 2 1x1 at tailgate end welded to make 1x2 but on flat. The double 1x1 is very rigid,considering its weight.theres 1/2" of vertical tubing wall and that part alone will carry what ever the ramp will support. IMG_2857.jpg
The lengthwise runs are jus 1/8"x4" flat stock.
Tooljunkie
May 13, 2014
4,150
27
So the aluminum box ford showed up. Driver says if i build it heavier than usual that would be great. Its real light in the back and hard to keep in a straight line on rough gravel roads.
Lets see what unfolds in the next few days....
2,855
Awwww, you know you will figure it, out and make it super good,, I have faith in you :D
clay45
L2050DT, TSC 5ft Rake, Tartar 5ft rototiller, TSC Middlebuster, TSC CarryAll
Feb 6, 2015
279
SC
I was building them at my previous job,now they want more. First of three i have to do. My new welder is working great. View attachment 29807
Have you told us about it somewhere?
sheepfarmer
Nov 14, 2014
4,444
661
MidMichigan
That is really cool! I could think of several uses for something like that...
