I own a K008-3 mini excavator. The right idler wheel has eaten the bearing so I need to replace it. I removed grease fitting and tried to push idler back to loosen track. No go. Tried using boom and a 4x4 to push back, no luck. Soaked everything with oil to loosen it up, no luck.
At this point I may have to cut the track off to get the idler assembly off unless one of you can offer a solution.
