I love Google! I had always thought surge brakes were used on boat trailers only since they are submersible.
A few weeks ago, two people were killed locally in separate pickup trucks when a semi trailer became detached on US50. I have not heard any more details as to why the trailer came off.Makes you wonder how an 80,000lb tractor trailer is only connected with a 3 inch nub of a king pin in the 5th wheel plate works. No safty chains either.
Air pressure from the tractor holds the brakes off on the tractor's trailer. If the trailer comes loose, or even if one of the air lines comes loose, the trailer brakes lock up and the trailer tires stop turning. If it comes loose from the truck, I would guess it stops pretty quickly. If it's still hooked to the truck, you get to see long black skid marks where the trucker is heading for the shoulder. If you happen to be along side of one when it happens, it scares the living doo doo out of you, especially if you are on a motorcycle. Took awhile to finally get relaxed that day.Makes you wonder how an 80,000lb tractor trailer is only connected with a 3 inch nub of a king pin in the 5th wheel plate works. No safty chains either.
I knew that, I spent a little over 2 years driving one. I was just throwing a mind boggling thing out there for the average person to thunk aboutAir pressure from the tractor holds the brakes off on the tractor's trailer. If the trailer comes loose, or even if one of the air lines comes loose, the trailer brakes lock up and the trailer tires stop turning. If it comes loose from the truck, I would guess it stops pretty quickly. If it's still hooked to the truck, you get to see long black skid marks where the trucker is heading for the shoulder. If you happen to be along side of one when it happens, it scares the living doo doo out of you, especially if you are on a motorcycle. Took awhile to finally get relaxed that day.
Edit - guess I should have read all the way to the end of the thread before responding. My bad...
