Trailer Break Away Battery Charging
3,256
What do you guys do to keep your trailer break away battery charged during the winter? I have a new trailer purchased this year that I'll be using over the winter months and would like to keep the battery charged and ready to go at all times. I really don't want to remove the battery for charging.
Should I not worry about it at all...and just use it as needed? The truck has a 220 amp alternator. I don't think there will be any issues charging that little battery when I'm on the road.
or
Since I'll be keeping the truck connected to a battery tender anyway, should I just connect the trailer to the truck with the 7 pin connector to keep the trailer battery charged? Is that a bad idea?
What do you think?
4,275
or
What do you think?
I just try to remember to hook up one of my .75A Battery Tender Jr's for a while every 4-6 months
58Ford
BX23s, LA340, BT603, RCR1248, PFL1242, STB1072
Jan 1, 2022
248
202
SW Washington
Anything that has a battery gets setup with its own trickle charger / battery tender. It would be a PIA to me to have to keep the trailer hooked up to the truck permanently but YMMV.
4,129
You need to test the 7 pin connector and see IF there's live 24/7 power on the center pin !! Most newer trucks have relays feeding power to the 'trailer connector' so may / may not have power ,unless truck engine is running.
If you're not going to use the trailer, remove battery, store in a warm spot, be sure it's fully charged....
B737
LX3310
Jun 9, 2019
2,024
2,197
New Jersey
Steve I just let them sit out the winter. The truck charges them up when it's hooked up to tow. If the light is yellow when I push to test before hooking up, usually by the end of the day it's back to green.
3,256
Agreed. Never worried about it with my other trailer. That battery has been dead for years.
I do plan on connecting the truck to a battery tender for sure.
mikester
M59 TLB
Oct 21, 2017
3,169
1,652
www.divergentstuff.ca
During the winter I make it a habit to plug in my trickle charger at the start of each month. I've hard wired quick connectors for my trickle charger on all equipment with a battery to make it easier.
4,677
or
What do you think?
If it has good sun exposure, harbor freight sells a solar charger with alligator clips pretty cheap. Clip it to the battery, and lay it out in the sun.
Biker1mike
Jan 11, 2022
1,165
1,253
Gallatin, NY USA
I take mine out, put it in the machine shed and put a trickle charger on it.
I could charge it in the driveway but with my luck I'd run over the extension cord while plowing.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,404
2,325
I 2nd the solar charger. Didn't have good luck with the HF one. Got a Battery Tender brand and it's been a few years.
To be fair to HF, the damage could have been done by me. I hooked the truck up before unplugging it. I might have bucked voltage and roasted it. Now it's always unplugged before hooking up the truck.
4,129
re: with my luck I'd run over the extension cord while plowing.
better than seeing how much of a 100' cord DOES get wrapped around and around and around a snowblower auger............
4,878
1,611
and I found out last year how well the mulch kit on my ZG127 works on 50' extension cord....wasn't much left of it a few pieces here and there but most of it was just mulched up.
