Tractor tie-downs
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
351
254
NH
Not sure that this is the right forum to place this, but here it is.
I have a 14' dump trailer that I use to transport my L5740 tractor when needed. Because the trailer is on the short side for this tractor, I remove the bucket and place the front of the loader up against the front wall of the trailer so that the tractor can't move forward. This also gives me more room to tie down the back of the tractor.
However, I find that there are no good tie down points on the front and back of the tractor to connect the tiedown chains to.
Any suggestions on how/where to do this would be appreciated.
Bearcatrp
Mar 28, 2023
1,252
865
Minnesota
Just do a google search for tractor tie downs. Allot listed. Find one that fits your tractor. If you have a tractor supply near by, they should have some.
3,014
I found existing bolt points and grade 8 bolts on my BX - D rings from Harbor Freight
11,316
Those are ridiculously expensive! 😲 $139 for one!
I welded on D-rings to the front "bumper" or weight bracket on both tractors. I have a spare front bumper for the MX and will redo the D-rings when I finally get around to fabricating a custom grill guard.
M6060 before painting.
MX6000
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,622
4,128
PEI Canada
11,316
139 per set. Still pricey but i don't have a welder.
I really like those binders.
Oh, I was confused by the second link which shows both brackets but only one bracket is shown in the first link. $139 is way more palatable and a good option for many.
I'm thinking about welding rings to the drawbars as close to the tractor as possible for tie down points. Perhaps a plate with a hole on both sides that wraps around the drawbar. Very easy to do and cheap.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,209
3,553
I don’t have photos, but I’ll explain the best I can. What I do on the dump trailer:
The rear is chained through a D ring shackle that is attached to the draw bar.
The front end is strapped around the loader mounting tubes with chokers. On the flatbed trailer I use the chokers on the front tires like a car.
4,045
Throw a chain over the axle-housings. Simple.
11,316
Those Peerless binders work well but I wanted six binders so I bought a couple of Easy Binders a few months ago but have yet to use them. Looks like I'll be trying them out in a week or so.
4,045
Expensive! (but Nice! … let us know how they work out)
imarobot
Apr 18, 2025
351
254
NH
Great info, thanks guys
