Tractor stuck in gear
Chi3fHunt3r
Kubota 2680
May 13, 2023
West Liberty
I have a Kubota bx2680 that's been having starting issues. It may start fine for awhile then out of the blue it won't start. All it will do is click. Nothing is engaged, has a good battery, etc. With the lever in neutral and in 2wd, I was going to push it up on my trailer but I can't move the mower at all. Parking brake isn't locked. It's stuck in gear and I can't move it forward or backward.
Please help. Thanks.
6,396
Need at least one more letter in front of the model number to help you out properly.
cthomas
LX2610 HSDC
Jan 1, 2017
865
579
La Farge Wi
It won't start? Or move? Is the shift lever moving at the transmission? Is the PTO engaged? Need more information about issue and how it started.
Chi3fHunt3r
Kubota 2680
May 13, 2023
West Liberty
It won't do either. I was going to load it up and take to my buddies house to look at. I can't get it started but I can't get it back into neutral to get it to roll.
cthomas
LX2610 HSDC
Jan 1, 2017
865
579
La Farge Wi
Clean battery connections and re-evaluate. Does the forward/reverse level move?
sitric
L2850DT Ferguson TO35
Jan 13, 2023
71
54
If it is a gear transmission,it may be stuck in 2 gears at once. I'm not sure Kubota's can have this happen. MF, and Fords certainly can, when the linkage gets worn, and the shift forks jump out of their slots.
Dustyx2
BX22, M7060, Landpride RC-2512, Woodmax SB84
Feb 19, 2021
217
NE Wyoming
It won't start or roll with it not in neutral. Try rocking the tractor while trying to move the shift lever.
cthomas
LX2610 HSDC
Jan 1, 2017
865
579
La Farge Wi
OK now does the level move at the transmission? Now unplug and replug every connection.
