Towing bx2350
bomber15
Kubota 2350
Apr 15, 2022
Manitoba
My second hydraulic oil filter failed on my bx2350. Like to tow unit about 200 years to my shop to work on it. 2 questions.
what would cause my filters to fail?
how do I put in neutral for a short slow tug of about 200 yards.
5,193
Doesn't the range selector lever have H-N-L, with N being neutral?
4,899
I'll assume it's similar to mine, so place hi-new-low lever to Neutral and tow slow ?
I did that 3 years ago, zero problems and went 400 yds+
bomber15
Kubota 2350
Apr 15, 2022
Manitoba
yes it does. Just wondering if there was more to it than that after reading other posts. Towing it very slow in neutral I should be good. Thanks.
Dustyx2
BX22, M7060, Landpride RC-2512, Woodmax SB84
Feb 19, 2021
217
NE Wyoming
Are these Kubota filters that are failing? Are they failing at start up (cold oil) or after running awhile? What oil are you using? What are you doing when it fails?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,805
1,522
WestTn/NoMs
What do you mean by fail? The can ruptures? Gasket blows out? Does this have two filters?
2,551
good question - got to be more to this, has my attention too.
bomber15
Kubota 2350
Apr 15, 2022
Manitoba
I used the Kubota
Changed filter, fluid and cleaned screen a few months back. got the correct filter and UDT fluid from Kubota. Worked good for 4 X 1 hour snow blowing. The filter seemed to split around the seam on the base. Filter casing would spin but base was snug. Gasket looked ok after getting it off. Will get new kubota filter and top up with UDT. Hoping it was a dud filter.
SRRGC1
BX1870-1, BX23S TLB, RTV XG850, MX5100DT
Jan 6, 2021
212
75
Bloomsburg
Are tightening the filter to much when installing? Have you added shims to the hyd. spring increasing the hyd. pressure? Could be just faulty filter.
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
"...My second hydraulic oil filter failed on my bx2350. Like to tow unit about 200 years to my shop to work on it. 2 questions...."
I think I see the problem. You've been towing it too long !
;-) <tic> <g>
Sorry--after 7 or 8 posts, and nobody saying a thing.; I couldn't resist.
I'll go stand in the corner now.
I got nuttin
