Tow behind spreader / sander
asgard
B2301, 60 inch deck, 51inch blower
Oct 22, 2016
147
15
Ontario, Canada
Well, another day tinkering in the workshop.
This year so far has been hard work with rain instead of snow and above seasonal temperatures making for an icy mess.
I had been looking for a cheap tow behind spreader and thought of modifying it to become a 3 point hitch unit with a small motor.
Well. as luck would have it I found a new in the box Blue Hawk 80 lb spreader just along the road, if fact the seller even delivered it.
Looking at the assembly and remembering I had some snow tires from a stripped down snowblower I decided to modify the tow along one with the winter snow tires.
Easy enough fabrication, a bit of cutting, welding in bushes for the shaft diameter and some nylon spacer and hey presto.
I did a picture showing the standard wheel and tire vs the snowblower versions.
It mounts nicely to my extended drawbar and attachment coupling- a previous fabrication job.
The hopper does not have an agitator which I thought was strange, but, I will try it before I add one.
CharlieFoxtrot
B2650
Dec 8, 2016
79
Northeast
I have a JD tow behind spreader that I hooked up like that to spread salt on my icy driveway. I found that I needed to add weigh or it would skip around on the ice and fail to spread. I put a piece of plywood over the top with a cinder block strapped on to it. Not ideal but it gets the job done.
Greenhead
L4400, MX5100
Oct 13, 2014
192
Fond du Lac, WI
Just as Charlie F stated I see a flaw. I always found it odd for a traction device to spread traction material in a non traction environment...
Perhaps running small hex head screws in the tires or should I say tyres ;) would help with traction. Also, I think you will need some sort of pig tail going into the bin to help the material come out.
2,163
In a smaller push style I had the "agitator" was a simple hairpin that went through a vertical shaft in the hopper.
asgard
Oct 22, 2016
147
15
Ontario, Canada
I like the R clip type idea, that would save a bit of fab work.
Like the "Tyres", I come from the UK and my US spell checker has me spelling badly.
I can if needed add more weight for traction but thought that these snowblower tyres would offer a reasonable starting point. Might try it out today on some ice.
Testing will prove the viability.
