Umm, just a guess but a bit more info would be helpful. Perhaps a pic tooDo they really worK?
Do you mean tooth bars for FEL?Do they really worK?
Oh ya...love my Piranha Tooth Bar, a ice eating monster. Have not fell once this year. Have not tried digging yet ground still frozen.Do they really worK?
I tried to use my BX without one.......ok worked fine, then I bought a piranha tooth bar, the usefulness went up 3 fold!!!Do they really worK?
The piranha is 1/2 thick, and it is very well made. The 3/8 with the right "pieces" would work very well too!How thick is the steel on the ones you guys have DIY or store bought.
I have some 3/8" flat bar laying around I may put to good use.
If that's for the L3200 in your profile, and assuming it's mild steel (usually safe if not otherwise specified), I suspect it wouldn't last long at all if used for the normal purpose. 3/8" mild steel isn't really hard to bend. It might work on a BX or a small B, but 1/2 AR400 or better would be my guess at a bare minimum for a copy of the Piranha on a tractor of that size. Or make one like I have that uses forged teeth mounted on fingers mounted to a base plate along with standard cutting edge.How thick is the steel on the ones you guys have DIY or store bought.
