Too cold to start
bywaterdustin2
45
Teulon, Manitoba, Canada
With temps at -39c the old girl won't start (M6950DTS) got a charger on now and diesel heater on oil pan. Thank God we also have small square bales to feed just a little more work
Sent from my XP7700 using Tapatalk
AKguy09
LX3310/ Cab 1950 F- Cub
Nov 22, 2017
103
46
ellicott, colorado
A block heater would be a wise investment, or one of the circulation heaters. When I lived in Alaska I would plug my tractor in about 3 hours before I wanted to use it, and it always started.
Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Dec 28, 2010
533
81
Mount Vernon, Ohio
Me too. 0F here today early (-18C). Definitely a battery for me for the M4500. Not complaining, first time in 7 years that battery hasn't started the tractor. Think i'll buy another just like it.
Stmar
B2650HSDC
May 23, 2017
908
42
Buffalo, Wyoming
Mine was in the barn and at sub zero even with the block heater and tenders plugged in still was the first time it did not start on the first try. Makes me glad the dealer installed the block heater and that Paul suggested the remote receptacle and all the guys that suggested the battery tender, had them on my ATVs so it made sense to add to tractor. I am also running #1, PS White and a dash of Seafoam just for the heck of it.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
336
My B started at minus 40*C. But the case 580 Super M needed a boost, but i think one battery is on it's way out.
JerryMT
Jun 17, 2017
528
156
The Palouse - North Idaho
When I am not using it it is always plugged in thinking it is finally time for a new battery
Are you sure your block heater is working? They do fail.
Battery heaters are also a good thing to have if you have really cold temperatures regularly, so you might want to consider that. Battery output drops and oil viscosity increases as temperature decreases so when you need more battery current, it isn't available. A battery heater together with a block heater can help.
JerryMT
Jun 17, 2017
528
156
The battery on our M4500 crapped out on us and it would not even heat the glow plugs, let alone turn over. The battery was 8 years old. I installed the new one this morning and I had the block heater plugged in and it started on the first turn.
prof.fate
75 L175, 14 toro timesaver, Landpride boxblade, countyline auger
Nov 9, 2017
155
Beaver, PA
my 73 L175 started this morning, 3F. Started easily..sorta surprised me that it did. Been sitting a couple of days in a barn. No heaters, no nothing.
3 year old batt.
My son's car has a 2 year old battery and it didn't start today.
It's very rare it gets any colder than this here. Glad it started - I now know I don't need to do anything.
Our diesel buses at work get plugged in for single digits. Boss complains about the elec cost of doing so.
4,544
3 year old batt.
I'd say you're in good shape. If that machine is setting inside a barn in that temp and starts easily, there's nothing else you can ask of it!!
Kubota Newbie
Dec 28, 2010
533
81
Mount Vernon, Ohio
What kind was it and how many cranking amps?
It was a Wallyworld Everstart 27DC which is a marine/deep cycle battery. 750 MCA which makes it about 660 CCA (but with a fairly long drawdown). The 27DC was out of stock this morning so I got the 29DC @ 850 MCA. It is a little bit bigger which makes it a tight fit (has to be exactly centered in the battery tray to easily clear the hood). $90
I know... Deep cycle batteries aren't for this type of application yada yada. But hey... $90... 7 years. Evidently works for this application ok. BTW divide MCA by 1.3 +/- to get average CCA.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
I put a Optima blue top marine battery in my M9000. It's been great for several years. I went with it because of the acc. post. Makes it easier to hook up the wires for bale monitors and such.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,158
949
Williamstown Ontario Canada
The block heater is part of the problem unless you have the latest model tractor.
The glow plug timer looks at the coolant temp and determines if the GP's are needed. Block warm, little to no GP time.
When the engine starts inhaling -20 to -40 cold air it wont fire.
There is a trick to bypass the GP timer. On my M7040, it is to put the shuttle lever in forward and turn the key to start. Count to about 10. Shuttle back to neutral and start the engine. The glow plugs have been on while the shuttle is in forward and the key in start.
Engine fires immediately.
The latest engines with all the emission stuff, have a programming change when the dealer installs a block heater. The computer is told to look at another sensor not influenced by block temp to determine how long to turn on the GP's.
Owner's who install a block heater on their own don't know of the programming change and continue to have starting problems.
Dave
bywaterdustin2
45
Well a new battery and some heat to the oil pan and she started up. It was nice to put out a large round bale yesterday and not hand bomb small square. Also put out hay for neibors and got more fire wood. Good thing because I woke up to -33c (-45c wind chill) this morning.
Stmar
B2650HSDC
May 23, 2017
908
42
Buffalo, Wyoming
My F250 sits outside and it was 10 below this morning, couldn't get it started yesterday but didn't try real hard. Today I used my Stanley lithium jumpstarter, have had it for over a year and never used it, and I'll be darned it worked. Hard to imagine a little thing like that starting a 460 F250.
pwhite42
L2250
Nov 1, 2017
Ashburnham
I had to replace my block heater on my Massey GC2300 this spring. The circulator heater on my Kubota L2250 has held longer. Both make a big difference when it is 10 below or lower.
