M Machz17 New member Jan 22, 2020 1 0 0 38 East concord, ny Jan 22, 2020 #1 On the L39, can you fit a bt1100 off a L48 or will only the bt1000 work on the L39? No one seems to have the answer. Sent from my iPhone using Tapatalk
G.rid Member Equipment L48 tlb, ssqa forks, manual thumb for hoe Aug 19, 2016 207 17 18 Oxford, NS, Canada Jan 22, 2020 #2 Bring your L39 to my place. You can try to hook up mine. Then we would both know! Lol You might be able to compare dimensions of the mounting bracket. Widths and pin to pin dimensions. Easier to check when it gets warmer again. Does the L39 have 3 hydraulic hoses to run it? The L48 does, 2 supply and 1 return.
