So, here is what the rake should look like. The 2nd, 3rd, and 4th pictures show what backing into a tree looks like. Thinking of taking the oxy-acetylene Rosebud torch, and removing the tines, then adding heat to a dark red, cherry red, and re-bending the 4" L bracket so that it's fairly straight. Without quenching it in water, so that it stays hard. To make it straight I'm going to use a 15-20 ft long piece of 2" round galvanized pipe with a cutout to fit L-shaped iron. Leaving the rake attached to the three-point Kubota and bending it straight using that galvanized pipe, by pushing in the opposite direction of that bend so that it straightens it out after using the torch on the L-shaped iron. What are your thoughts?
