Getting of diesel smoke hanging in the garage for a long time having to keeps the door open in cold weather, problem solved.... I had my cousin weld a 1 1/2" male pipe thread onto the end of the mufflers removable tailpipe to make it parallel to the side of the FEL. I then screwed on a 1 1/2" elbow and attached a 1 1/2" PVC adapter to a length of 1 1/2" PVC pipe about 5 feet long and drilled a hole to pin it in loosely. With the extension pipe attached I start the tractor in the garage blowing the smoke outside, I pull out and remove the extension and adapter. It never gets hot enough to overheat the plastic. Plus because its threaded I can raise and lower the FEL and the extension moves up and down with it.
<P>
<P>
<P>
<P>
<P>
<P>
<P>
