tire down
bcarver
l3200 Fel box blade, Bionic Blade, 4ft bush hog, Ken's bucket hooks
Dec 17, 2016
15
Crystal Springs MS
I rolled the rear tire off the rim. I got it back on but now it is air only. How do I refill with water. L3200 with industrial tires.
5,533
Was it filled with water before?
Or was it filled with something that doesn't corrode or freeze?
cash
9
Pittsburgh
I have a White GT-1855 and when I did it I used the orange hand pump at Harbor Freight and got the valve stem to the top, took the cap off, took the valve core out and then filled the tire 75% full, put the valve core back in and put air in it.
I put a cable tie on the end to keep it on the valve. I can't remember now if you have to jack it up or not to fill it. Would think it would be better to do.
I used the -30 or whatever washer fluid. Using plain water is probably bad if you are in a colder climate.
bcarver
Dec 17, 2016
15
Crystal Springs MS
Not sure what it had in it. It was done at dealer. It did have a smell but more like tire than anything else. Central Mississippi ...cold is not an issue but corrosion would be.
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,189
119
Coyote Flats,Texas
With the aid of this tire liquid valve one can install water in tires simply by attaching water hose to valve. Turning off water faucet every few minutes to bleed off air that pressurized water puts in tire along with water. Place valve stem at 12 O'clock. I've filled many tractor tires when I was employed at a farm equipment dealership. If water covers rim(75%) there will be no air touching rim to form rust.
Blondie70
L2501DT('18)L2501('15)
Aug 6, 2016
256
Poplarville, MS
I live in South Mississippi and my dealer fills with plain water. I have used the tire attachment like in the previous post to top 'em off with water . Get a jack under tractor and jack the weight off the wheel … but don't jack the wheel up off the floor. If you jack it up in the air, the weight of the water (before you repressure it with air) can pull the tire off the rim. (I read this somewhere and it makes sense)
Good luck up thar in Crystal Sprangs.:D
rentthis
1,004
23
38
summerville,sc
If you decide to put antifreeze, corrosion additive etc in the tire, take a funnel and pour it into the water hose and attach it with the fitting Tx Jim posted. The water pressure will push it into the tire.
