In addition to Geohorn's comment to keep the bucket low as possible at all times, the same goes for the 3 point implements. From the OP's pic it looks like the rear box scraper was up quite a ways although while tipping over it might have slid to that position anyway with no down pressure. In any case and for safety's sake the same advice applies to both ends of the tractor. To keep the center of gravity low, both the loader and 3pt. implements should be kept at the lowest possible level.
If on uneven ground or working on a slope with the loader I always keep one hand on the loader valve and am ready to dump/lower the loader boom as fast as possible at the point where you know it's becoming unstable. Then its the same for the 3 point hitch and time to reassess the situation.
Glad you're ok and hopefully with little to no ill effects suffered to your nice tractor!!
