I need a 50 hp tractor/fel that will handle a Farmi, work as a bulldozer, brush hog and plow snow. Which Kubota is actually a 50 hp UTILITY tractor?
I know of no farm tractors that function properly as a bulldozer.I need a 50 hp tractor/fel that will handle a Farmi, work as a bulldozer, brush hog and plow snow. Which Kubota is actually a 50 hp UTILITY tractor?
Kubota lists the MX and M60 tractors as utility tractors, but there are quite a few Kubota tractors in the 50hp and up range capable of handling a Farmi winch, moving dirt, brush hogging and snow plowing. The Grand L60 Series, M62 (more commerical grade) and probably some others.I need a 50 hp tractor/fel that will handle a Farmi, work as a bulldozer, brush hog and plow snow. Which Kubota is actually a 50 hp UTILITY tractor?
Same with the Kubota model of submarines, but we see that occassionaly.I know of no farm tractors that function properly as a bulldozer.
I own a MX6000 and like the tractor but I think the three point might be a little light for the kind of work you want to do, When you mention bulldozer's and three point winches you may want to look at more of a construction grade tractor. I have seen many 100-150 HP farm tractors destroyed when folks added front mount blades on them and thought they were a dozer.I need a 50 hp tractor/fel that will handle a Farmi, work as a bulldozer, brush hog and plow snow. Which Kubota is actually a 50 hp UTILITY tractor?
