Tight front hyd pump bearing on L35
wmurphy
L35
Jan 12, 2019
Whitefield, NH, USA
Hello,
I have replaced the rigid hydraulic lines coming off the front hyd pump on my L35 (Supply and return). At the time of removing the front pump with the L-bracket still attached, the pump rotated freely.
I had to remove the pump from the bracket in order to remove a broken bolt from the L-bracket.
In the process of reassembly, the pump is now difficult to turn.
Is it normal on reassembly for this to occur? (as if there is a bearing preload that was re-established).
thanks
Will
wmurphy
L35
Jan 12, 2019
Whitefield, NH, USA
I put a small set of shims between the L bracket and the pump....rotates fine now. Could be a ridge in the pump shaft relative to the bearing or possible corrosion on the al pump face causing it to interfere now. See how it goes now.
L35
Jun 13, 2010
532
441
CT
Thanks for the follow up
