Throttle dodad falling off...
klar5020
Kubota BX1880
Apr 10, 2017
Las Cruces
www.riobravoalpacas.com
I've got a BX and the rubber doodad on the end of the throttle lever keeps falling off... I keep twisting, pounding, and pushing it on but it doesn't go on very far and eventually falls off... Has anyone replaced it with some other doodad? Like a die or something cool like that? Not a big deal but it keeps bothering me.. Other than this goofy thing it's a great tractor.
Larry
2017 BX23S
2,675
Larry
2017 BX23S
It slides over the steel shaft? It is a slip fit - no threads?
Either way - go to wally world, get some 2 part epoxy, mix 50-50....
place a dab or 3 on the shaft, slide "doodad" on, place where you want it.....
30 minutes later (depending on what you used) you are good to go!
7,242
And good luck getting it back off :rolleyes::p:D
Sent from my SM-G920V using Tapatalk
Ramos
1870-1, LA203A, RCK54
Feb 25, 2016
463
Sherman County, Oregon
I used some Automotive Goop (real name, by the Shoe Goo people) from NAPA. It has good adhesion and is somewhat flexible when cured. That was a year ago and it's holding just fine. All but certain I could break the bond by twisting if I ever had to remove it.
2,675
That little bugger aint sposta come off to begin with! I think the stick'em that Kubota used wont stick'em enough!:p
Ramos
Feb 25, 2016
463
:D
Yeah, no reason to remove unless a guy somehow ruined the grip itself and needed to replace it. If that was the case, destroying the old grip would be irrelevant.
