D Doug 3300su New member Equipment Kubota 3300su loader backhoe Nov 12, 2019 1 0 0 United States Nov 12, 2019 #1 I have a 2250 in the shop the three point won’t raise changed filters and hydraulic oil already the loader will go up only but not fast and will only go down if you put it in float any ideas thanks in advance
Pau7220 Well-known member Equipment L3650 GST, Landpride TL250 FEL w/ Piranha, 6' King Kutter, GM1084R Finish Aug 1, 2017 785 279 63 Scranton, PA Nov 12, 2019 #2 Sounds exactly like my symptoms when a stick hit a quick disconnect. Check your quick disconnects on the loader hoses. Disconnect, check for debris, then reconnect.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,983 9,186 113 Sandpoint, ID Nov 12, 2019 #3 Quick disconnect not seated or flowing because of blockage or failure, or selector on the Hydraulic block is in the wrong position.
