Three point won’t raise
Doug 3300su
Kubota 3300su loader backhoe
Nov 12, 2019
United States
I have a 2250 in the shop the three point won’t raise changed filters and hydraulic oil already the loader will go up only but not fast and will only go down if you put it in float any ideas thanks in advance
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Sounds exactly like my symptoms when a stick hit a quick disconnect.
Check your quick disconnects on the loader hoses. Disconnect, check for debris, then reconnect.
9,184
Quick disconnect not seated or flowing because of blockage or failure, or selector on the Hydraulic block is in the wrong position. ;)
