Thoughts on a PTO powered capstan winch?
timber and wine
L4802, loader, forks
Nov 1, 2026
41
37
NE WI
My capstan experience is limited to a railcar installation. This small manufacturing plant received sugar via hopper cars, and needed the ability to move the car to the unloading spot as each compartment was emptied. They had a (5 hp as I remember) capstan installed by the track and used a 1" or so cotton rope with a big hook on the end. The capstan was geared to maybe 10 rpm and had plenty of pull to break the rope if the operator got in a hurry. They stood well off to the side and hid behind a sheet of plywood.
IMO, it's the operator who controls the tension, an extra wrap around the spool multiplies the traction, and he/she should be prepared for breakage. Releasing the pull on the rope tail instantly stops it. Just don't let the wraps overwrap and lock up.
Excellent information... Thank you.
Moving rail cars! so plenty of power generated. Cotton rope is pretty stretchy, though not as bad as some of the cheap synthetics. Sounds like the synthetic winch ropes are much safer.
And I hadn't thought of the overwrap potential on the capstan. I can see how that could lock things up. Again, in these situations slow is much safer than fast!
timber and wine
Nov 1, 2026
41
37
NE WI
One thing I didn't notice while perusing this thread is the loss of maximum puling force experienced winding a cable around a drum. Each layer of cable effectively makes the drum a larger diameter. A capstan winch applies a constant maximum force.
If I was to build some sort of PTO powered capstan, I think I'd like an electric clutch with a deadman's switch to stand on. That would enforce safe positioning.
I like the "deadman" switch idea (gee wonder how it got that name :rolleyes:). Of course all the added complexity increases the cost.
Remember back when I said I have an "I can build that" problem? Most of the time I'm right... I can build that myself. Unfortunately, sometimes in the end, my version is nearly as functional as the original at only double the cost!
GrumpyFarmer
5,317
I’d offer again do a demo on the logging winch…maybe not popular option on this thread…but until it’s tried maybe hard to understand the productivity difference with and without a skidding plate. (At least try or go look at a skidding plate, or don’t, it’s your money and energy)
honestly without the skidding plate itself (with chain slots…whether have winch or not), if have the rope and some shackles I am not sure what the capstan really achieves other than reel the work in…but with ropes and proper rigging/pulleys, you could just the same log out to where you can work on it. And once you can back up to the log put a chain on and go. That still would not offer the productivity of the skidding plate itself.
IMO, there are plenty of logging threads on this site that suggest @NCL4701 and @North Idaho Wolfman is shooting you straight. JMHO.
Sawdust&Shavings
BX1870,LA203A,BX6315,BX2767,RCK48-18BX,GCK60-23BX
Apr 25, 2023
232
279
Stafford, VA
IMO, there are plenty of logging threads on this site that suggest @NCL4701 is shooting you straight. JMHO.
As a kid we used a car engine hood/bonnet flipped upside down and it was fast, simple and cheap/free.
GrumpyFarmer
5,317
Yep…I don’t disagree on the low budget option…make a great sled in winter too.
All I can say is I have gone from log chain, to home made triangle on the rear with chain slots, to a logging winch and the plate makes it extremely productive and it protects the back of the machine during operation and while traveling. If I were doing any type of winch capstan or pto, I think I would try to integrate into some sort of skidding plate.
from a can/could/should we make a capstan solution I get i get the challenge/creativity, but I am not sure what problem the capstan solves more efficiently than other options. JMHO. IMG_3205.jpeg IMG_3210.jpeg Resized_20260808_121302.jpeg
torch
Jun 10, 2016
2,912
1,173
Muskoka, Ont.
I'd be less concerned about the material the rope is made of and more focussed on how the rope is made. This calls for kernmantle construction with a static core. I'd look at a caving type rope, which has a denser weave to the sheath and is more abrasion resistant.
Synthetic materials can and are also used to make twisted and hollow core braided ropes, neither of which would be suitable IMHO. So 'synthetic' alone is not sufficient assurance. Again: IMHO.
timber and wine
Nov 1, 2026
41
37
NE WI
from a can/could/should we make a capstan solution I get i get the challenge/creativity, but I am not sure what problem the capstan solves more efficiently than other options. JMHO. View attachment 181914 View attachment 181915 View attachment 181916
Thanks for the excellent pictures. That is the first thing I want to make for use this winter... that and a log wagon. I have seen versions and was not sure what it was even called. I really like that design and intend to steal it!
My past logging/firewood cutting has been with my old Allice Chalmers WD, and I would just pull them out with a collection of chains and tow straps until I could get over them. Of course the Allis has a drawbar setup not a true three point and it did not work well. So it was more dragging than lifting. I could reach out and grab a log from maybe 150 feet with what I had. Good enough for what I needed. I would pull them to a landing then a nieghbor would come out with a skidder and load them on his trailer to bring them around (I need to go by road to reach some of my woods).
You are correct... I do not really need, nor do I intend to buy, a forestry winch. Thanks for the demonstration offer by the way, I do not doubt their functionality. Most of what I need to do can be done with the right straps/chains and straight pulls. With a funtioning PTO, a skidding plat (like you have), forks, and a log trailer my productivity will be greatly improved If I add a good pully for directional changes I'm probably set. Mostly.
I do have some wood that is 500 feet or more into or across some really wet marsh. That is where the capstan winch idea was born. There are times where a really long pull is needed and I was thinking about a portable unit even before I bought my new Kubota. As luck has it, this has been a really dry year* and I think the marsh is dry enough that if I pack her down wth the side by side I should get enough frost to drive the tractor across this winter.
The capstan is not on the short list of needs, more like one of those "hey I could do that" ideas. Not saying I will never give it a go, just not now. If I need to install rear hydraulics for anything else, that pretty much asures I would go with a hydraulic motor capstan mounted on top of the skidding plate/triangle.
Also, the discussion has been enlightening for me and hopefully others. I have learned a lot.
* How dry you ask? in 2020 I needed chest waders to drag deer out of the swamp. This fall I could walk across in socks and not get wet feet! I have a small excavated pond on the edge of the cattails and the water level is now 3-feet below the surface of the marsh.
GrumpyFarmer
5,317
You are correct... I do not really need, nor do I intend to buy, a forestry winch. Thanks for the offer by the way, I do not doubt their functionality. Most of what I need to do can be done with the right straps/chains and straight pulls. With a funtioning PTO, a skidding plat (like you have), forks, and a log trailer my productivity will be greatly improved If I add a good pully for directional changes I'm probably set. Mostly.
The capstan is not on the short list of needs, more like one of those "hey I could do that" ideas. Not saying I will never give it a go, just not now. If need to get rear hydraulics for anything else, that pretty much asures I would go with a PTO powered capstan mounted on top of the skidding plate/triangle.
Oh my…sounds like a duck and goose refuge!
That rear triangle is now a big paperweight…PM me if interested and make an offer, if willing to come get it.
if not I would highly recommend to look into make / or buy some cheap skidding plate options before trying build. (I took a catalog engineering approach and honestly I should have put my money in S&P500 index fund, weight a few years and then bought the logging winch.)
Send some Pictures whatever you come up with. Good luck.
timber and wine
Nov 1, 2026
41
37
NE WI
Thanks for the offer but Ohio is a haul and i don't see getting down that way anytime soon. I'm not familiar with all the terms ( skidding plate, triangle, log arch). I looked up skidding plate, that's not what I'm looking for. I would like a triangle implement like you have for pulling and lifting the front of the log for skidding, the chain storage is a plus. I also plan on making a skidding cone from a blue barrel.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,501
707
Richmond, Virginia
I have a small capstan winch in my shop. Supposedly, can pull 2,000 pounds. I have a stack of ladders (400 pounds worth) I store up on the ceiling. I can... pull them up by hand (three pulley block setup) its still tough. The Capstan winch works great Rope wrapped around it about five turns, switch on. As soon as I put some tension on it, up the ladders go. Slow,m hand over hand pull. The moment I et tension go, it stops pulling (The device I use has an auto cleat that locks the rope in one direction and from about 45 degrees away, releases, very safe).
As with any pulling/lifting, have gear that has a lot more capacity than you can use/pull/lift. Think.
BX23-S,57 A-C D-14,
6,344
the A-C WD has the 'Snap Coupler' version of 3PH, actually superior design. My D-14s have it , made a S-C->3PH adapter to run the 5' rototiller. Takes less than a minute to atach to any D-14 and no top link adjusting needed.
