What are you seeing as the main danger?
Snapback, obviously, but that's mitigated by proper operator positioning, the same as when using any tensioned cable. What am I missing as far as hazard unique to a capstan winch?
I've also considered DIY'ing one - curious what you guys are so worried about...
So I log maybe a dozen trees a year, and due to living on horribly rocky property, just getting to the trees is half the battle. A winch is the obvious answer, but the electric ones aren't really up to the task, and a Farmi-style winch cost too much for how little I'd use it. Thus I eventually...
www.tractorbynet.com
Sorry for the long answer, but you asked…
This is the only one I’ve seen set up for logging with a tractor. It’s driven by a hydraulic motor powered by the tractor hydraulics.
https://norwoodsawmills.com/products/skid-winch-hydraulic-log-skidding-winch-for-tractors
This is one of the pictures off their website.
The operator has one hand controlling the rope and the other hand on the hydraulic control valve that has been placed such that it can be operated standing at the right rear of the tractor. Hydraulic motor has practically zero inertia. Anything goes wrong, the drum stops with the flick of a wrist.
With a PTO powered capstan, to stop it you have to disengage the PTO. Maybe you can reach the PTO button while you’re working the rope if you’re pretty tall, but it would be somewhere between very awkward and impossible. (A L4802 is substantially larger than the tractor in the pic above.) An emergency shutdown likely wouldn’t be instantaneous even if you had one hand on the button as the driveline has quite a bit of inertia. Maybe you could work around that with some sort of clutch in the driveline. Unless you stand over the top of it, you’ll have to turn the drive 90 degrees to get the drum vertical so you’ll need to fabricate some sort of driveline anyway.
The other issue, for me anyway, is the only capstan winches I’ve seen for sale or dealt with were the 1000lb to 3500lb max line pull size, powered by small gasoline engines or hydraulic motors. You’d be hooking a capstan to an ~40hp diesel engine. Max line pull may be limited by the friction of the rope turns on the drum, but with an engine of that size, there’s potential to generate many thousands of pounds of line pull. Ropes, cables, chains, brackets, and anything else failing at 3500lb isn’t exactly safe, but whipping, shrapnel, etc. isn’t much of a concern at that low of a line pull. With a 40hp winch, if something fails it can go very badly. How much line pull will a 40hp capstan winch generate? I don’t know, but I know if you underestimate line pull and that leads to busting an undersized piece of rigging you’ll need to be behind a good cage.
I have some old chains, ropes, shackles, and other miscellaneous rigging we used with the smaller tractors we had before I got my L4701. Being a thoughtless dummy, I assumed all the rigging we historically used with trees and the old tractors was fine to use with the L. After breaking a couple chains (repeatedly), pulling a rope in half, and stretching a shackle to the point we had to take it off with an angle grinder, it dawned on me that we had to review all our rigging to make sure it was sufficient for the L’s max drawbar. The Farmi will pull more than the L’s drawbar. The Farmi will pull 11,000lb single line with nominal strain on the tractor engine even at idle. We retired about half our rigging and upgraded where needed.
What will your 40hp capstan winch pull? What kind of rope are you using? Does it have a jacket sufficient to withstand use with a capstan? Does it have any stretch in it? I know a lot of people (online anyway) say rope doesn’t whip like wire rope, but have you ever seen a shackle fail on the end of a 120’ 3/4” rope that’s stretched to around 130’ under the tension of applied by a F450? If a good part of the shackle hangs on the end of the rope it will come at you like a sling shot from hell.
I’m not saying you shouldn’t do it. If you do, I hope it works great. Maybe you can figure out some way to stop the rotation without delay. Maybe you can do some testing to figure out line pull close enough to size the line and rigging.
Maybe I’m a handwringing pansy. But based on my experience with trees and ropes and winches and various associated rigging I would not be at all comfortable operating a winch I couldn’t stop instantly, and you couldn’t get me within 100’ of a 40hp winch with unknown line pull and therefore unknown adequacy of winch line and rigging.
