Thoughts on a PTO powered capstan winch?
timber and wine
L4802, loader, forks
Nov 1, 2026
14
NE WI
I have a lot of low ground where i cut firewood and lately winters cold enough to freeze the swamps are the exception to the rule. With my old Allis I would string out lots of tow straps and pull. With the new tractor I've been researching winches. I think the PTO logging winches are more than I want and I don't relish the thought of pulling cables around. I have used a portable capstan which and really like them.
I've seen One commercial and some DIY hydraulic capstan Winches but I don't have rear remotes. Using a gear reducer (and maybe a sprocket reduction) could you rig up a PTO powered capstan winch?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,235
1,214
E.
sure they sell kits and complete systems but w/ capstan winches brakes / locks may be sorely missed.
Land Rover used them for decades.
Land Rover clubs / retailers often sell diy kits, plans, complete systems, etc... that are pto powered.
And on the plus side used LR cap. winches are almost same as tractor pto speed of 540.
timber and wine
Nov 1, 2026
14
NE WI
I haven't found any kits. Do you have some links? The Land Rover kit looks cool but I imagine anything LR would cost a fortune.
I don't see how brakes would be an issue with a capstan. If you want to stop just release tension on the rope. Not sure how a lock might work but not an issue for me. My ground is pretty flat.
timber and wine
Nov 1, 2026
14
NE WI
Related question... The tachometer has a PTO operation range. Is this just because most attachments are designed for a standard PTO rpm? Is there a problem operating the PTO at a lower engine speed to obtain a lower PTO rpm?
11,482
There a reason you don't find PTO capstan winches, they would kill you in nothing flat!
Get a logging winch!
timber and wine
Nov 1, 2026
14
NE WI
How so? (Its a serious question). To my mind the capstan winch is inherently much safer than a cable winch with the slow rotation speed and built-in speed control. I've seen chain breaks and snap backs but not a cable break. Still I assume a rope break would be less violent.
My main issue with the forestry winch is pulling the cable around and the limited length.
Also there is this thing in me that looks at everything I could buy and says " hell I could build\do that". It's served me well in all aspects of building trades. If I can up my welding game it would open up whole new worlds😂
11,482
When dealing with logs I've see and dealt with just about every scenario.
Ropes and log pulling are a HUGE NO!
Might as well make a giant slingshot and pop yourself with it.
Seriously, ropes turn into rubber bands pulling and when they break they can become a giant whip.
There is no way I want to be operating a capstan winch when that rope breaks.
Watch the video of the Wallenstein logging winch and you'll see where it has safety build into the design.
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
284
237
Indiana
Don't overload the rope. Don't let it overheat around the capstan. Keep yourself off-axis of the tensioned line. Rope itself *can* be safely used.
11,482
I guess I stand corrected on all counts:
timber and wine
Nov 1, 2026
14
NE WI
I understand your concern. I did some googling and there are a lot of claims that rope made for winches is safer than cable... Less stored kinetic energy. Of course those ropes are not inexpensive. I'll keep studying it but at this point it looks like the cheapest solution would be to buy a portable capstan for logging and attach it to a homemade trailer mover\log drag
Luckily it will not be an issue this winter. We are in a drought here and the swamps are very dry. I shou!d be able to drive across them to get the last of the ash for saw logs. gotta strike while the iron is hot!
JailBreak Your Tractor
Vendor Member
BX25D
Nov 26, 2024
37
29
Ozarks
On the PTO speed question: the PTO range on the tach is just where the shaft turns its rated 540, which is what most implements are designed around. Running it slower won't hurt the tractor. You just have less horsepower available, since the engine makes less power at lower rpm, and the hydraulic pump flow drops with engine speed too. For a winch, slower is usually what you want anyway. Just don't lug the engine under a heavy pull. Bump the throttle up if it starts to bog.
