BozenBota
LX2610; RCR1542, FDR1260, BSS54P, PFL1242, STB1072, MacKissick TPH123, SCG0660
So I’ve been thinking about this post for a bit: What is in your head when operating to preserve your tractor long-term?
Im thinking mainly the tractor and loader (ie as opposed to other implements), and when operating (ie as opposed to maintenance, storage, trailering, etc.).
I may be entirely naiive to the things — especially the little things — that damage what are really durable machines, especially over time and repeated use, and so I need to say that in preface. And of course there’re times and reasons to push and abandon general rules. Also, I do regret if this has been covered in another post and would stand down from further discussion here of that’s the case.
But here’re some of my practices:
-smooth operation over all else is inherently best—probably informs this entire post: avoid abrupt loader movement (jiggling when dumping, hitting the movement stops, abrupt up/down movement), hydrostat engagement, PTO engagement, etc.
-keep front loader arms as low as possible, especially with a load, and regardless of roll or pitch angles
-in general, run at higher RPMs, but match engine speed to task, and avoid lugging engine
-warm up machine (eg so that temp gauge elevated above cold) before placing even modest loads on the drivetrain; in hot weather, allow to idle a bit after working (ie to accelerate system cooling)
-with a non electric, non foot clutched PTO, engage PTO implements gradually
-strenuously avoid torquing loader arms side-to-side with off-center loads; load front loader implements as evenly across loader arms as possible
-with any heavy load (pulling, climbing hills, on the loader, on the PTO, etc.), slower travel speed is best—same on uneven, “jouncy,” ground
-avoid extremes—of loader angles, steering angles, loader or 3pt lift capacities, travel speeds, operating terrain, etc.
If you’re at all like me, a mental framework goes a long way, in multiple senses. So I’m curious the group’s thoughts.
