Thanks for all the Answers, Ordered my B2601 Today!!!
PaulR
Aug 3, 2020
581
460
Hadley, MA
Search here you may find more info. I'm not a pro at all but from what I think I read here, the diverter robs the up/down function of power, where the third function does not. A snow deflector needs such little strength that they use only a diverter here.
davidmem
Soon to be owner of Kubota B2601 Toro TimeCutter Model 7577
Mar 14, 2021
179
79
Bethany, CT
That makes sense to a newbie (me). The blower will be in float most of the time.
I appreciate it. I imagine they strap on a switch to the joystick. That's probably included in the kit and drives the kit cost up
ltpeto164
Kubota B2601, turf tires, 60" Grapple, 55" snowblower, LP Land Planner, MMM
Dec 9, 2020
Northern Wis.
Hello Davidmem, like Paulr said, since you have a hydraulic shoot deflector, it would be best to have a 3rd function valve installed and needed for other fun attachments you'll probably want to make jobs easier. I attached a pic of what my 3rd function valve looks like. On top of the joy stick is an added plastic knob, I don't remember what the original looked like. You can't see it in the pic, but there are 2 buttons on the left side of knob that control 3rd function hydraulics. The black vertical bracket with 2 hoses is also part of the 3rd function valve kit. I also attached my sales sheet with the items needed for snowblower. Yes, it is not cheap but if you want easier work for yourself, I think it was well worth it. Hope this helps clear things up for you.
davidmem
Mar 14, 2021
179
79
Bethany, CT
Thank you VERY much. It certainly clears up how the third function works with snowblower.
What remains a mystery is what my configuration will look like. Supposedly, in the $1,048 price for the hydraulic chute deflector "kit" are enough parts to make it work WITHOUT the third function. Maybe I should ask if anybody has a picture of that?
Implements I will use are the FEL of course, pallet forks, and tine rake(if I can find one).
I'm not sure about how I would use a grapple here. My 1.6 acres is all cleared. Maybe to grapple wood and carry it over to the splitter? I will think about it......
VERY MUCH appreciate the photo.
If the third function was REQUIRED I would have passed on the hydraulic deflector, but it IS an awesome feature. I just don't see a need for it yet.
Thank you!!!!!
ltpeto164
Dec 9, 2020
Northern Wis.
I can attach pics of what my set up looks like later today or tomorrow. I thought at first too: "how hard can it be to manually move the chute up and down" but I am sure glad I have it now. When blowing snow and it's windy out, and if you do have to try and blow into the wind or cross wind, moving the chute deflector is necessary, or else you will get a face full of snow. Sometimes you want to blow it away far, but in tighter spots sometimes you can't. Don't want to break windows or hit buildings. You would end up moving the deflector more than you think. Getting on and off the tractor can get a little annoying. You can also go to YouTube and watch GP Outdoors channel. He had a B2601 with a snowblower. He has great video's about the tractor and the attachments. You can watch the snowblower in action.
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
337
100
Ottawa, ontario
I have the BX2755HD blower and because of the price opted not to install the hydraulic chute deflector. Installed an electric linear actuator and for less then $100.00 can tip the chute. With my old 3 point blower it had a fixed deflector so I thought how often would I change the angle. I do use it more with the front blower to prevent snow in the face. Its a lot of money to go up and down.
PaulL
2,570
1,537
NZ
I think I'd talk more closely to the dealer. If you get 3rd function, you'll save some on the snowblower as there are parts that won't be needed. I think you'd be happier with a full third function than with a snowblower-only third function, which is effectively what you're buying. Doesn't hurt to ask them what the saving at the snowblower end is, and the cost at the tractor end. I don't have a third function nor a grapple, but a lot of people do and love them. I don't know what you'd use it for, but sounds like you're specing your tractor to be a fun toy, and you may regret not taking that last step.
davidmem
Mar 14, 2021
179
79
Bethany, CT
I did watch that....it cost me money. :)
Thank you.
davidmem
Mar 14, 2021
179
79
Bethany, CT
Thank you....I will talk to the dealer on Monday.....
I appreciate the input.
ltpeto164
Dec 9, 2020
Northern Wis.
Here are some pics of what the hydraulic chute deflector looks like on my blower setup. It is ridiculously priced but having a remote chute deflector is a must if you're going to be snowplowing around buildings and vehicles. I was getting the factory installed 3rd function valve anyway because I was getting the grapple attachment, so in the moment of buying I added the hydraulic chute. After having it now, I'm sure glad I did.
davidmem
Mar 14, 2021
179
79
Bethany, CT
Thank you, and thanks for the pictures.
If I can think of how I would use the third function, I'd add it. That would bring the cost of the shoot deflector to over $2000 if I add the third function.
Maybe I could use the grapple for my firewood activities......
Thank you again...
David
Dmidaho
Kubota B2601
Jun 15, 2020
Idaho
Hi davidmem,
I haven't read the entire thread, did you order a rear remote? That could be used for a hydraulic shoot deflector with hoses long enough to reach the connectors. I am torn between adding a hydraulic shoot deflector using my 3rd function or adding an electric actuator as thebicman suggested. I've got all summer to work that out, however, I am in the process of sizing/ordering a hydraulic top link, it is about Box Blade season here in north Idaho.
Ordering/receiving my tractor was a nightmare! It is a long story but the Cliff's notes version is I ordered the hydraulic shoot deflector, dual rear remotes and top-n-tilt kit (signed and delivered the order form to the dealership June 1)... When the tractor was delivered (November 19th), these three accessories were not on the tractor (well, I did get a single rear remote) and the salesman just laughed and said, "Thank goodness I didn't charge you for them or I'd have to take the tractor back!" UGG!
There is much more to the story. Ultimately, I am in love with my B2601 (Thanks GP Outdoors for helping me decide) but am not happy with the dealership. Unfortunately, one family has a monopoly on Kubota in my region so if you want a Kubota here, you have to get it from one of their "stealerships". I called several other dealers in other geographic locations and all said they would not sell me a tractor since I was in ____'s territory.
Sorry for the grousing...
Not knowing your particular needs for a tractor, I anticipate you will love the B2601! I really like the cabbed LX2610 but decided $5-6K will buy a lot of winter clothes and don't think I need the extra size/weight!
Here is my "toy" configuration:
B2601 with loaded R14T tires and rear wheel spacers, LA435 w/60" SSQA bucket and 3rd function
Land Pride (LP) SGC0660 grapple
LP PFL1242 pallet forks
BX2822 snow blower
LP BB2560 Box Blade (hence the desire for a top-n-tilt kit)
LP RCR1260 rotary cutter. In hindsight, I think I should have paid a bit more and ordered a flail mower instead of the rotary cutter.
Here is a couple photos of my snow removal set up:
Forgot to mention, I've added lights to the ROPS and some small white LEDs to light up each side since 90% of my snow blowing is after dark and also added amber flashing LEDs to each side of the tractor. I don't have any photos of the lights (I'll have to take a few!) but I think it came out pretty good.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
335
554
NH/VT NEK
You will love it. I love mine and I have no regrets.
davidmem
Mar 14, 2021
179
79
Bethany, CT
Thank you Dmidaho. What a beautiful part of the country. Skiing there is on my bucket list. I appreciate your time to try and help me. GREAT pics of your tractor......
Completely embarrassed to say that I don't know what a rear remote is. I'm guessing it's a different control for the hydraulics that lower and raise the 3 pt hitch?
I'm interested in adding some lights. My Toro TimeCutter was VERY EASY to add lights as there was already an "RV" style plug coming off of one the electrical harnesses. Any provisions in the B2601???
I remain confused about my snowblower and how it will be configured without the 3rd function. Still looking for pictures for that configuration up front (where switch is etc).
David
6,907
No reason...have to learn somehow..
A rear remote is an additional hydraulic "circuit" in the back of the tractor.
Think of your loader using 2 circuits; one lift/lower, the other curl/dump.
These are just located in the back of the tractor with a separate control lever for each remote.
Folks will often add more than 1 rear remote to accommodate things top and tilt (2 required), or other hydraulics on rear-mounted implements.
davidmem
Mar 14, 2021
179
79
Bethany, CT
Thank you. If I understand, by tractor, not having a rear remote, will have ONE CIRCUIT for lowering and raising the 3 point hitch. So if rear implement needs to move up and down as well as say, ANGLE A BLADE (maybe) then that is where the rear remote comes in.
Much appreciated.
B737
LX3310
Jun 9, 2019
2,022
2,204
you can angle a rear blade/rake by using the 3rd function.
If you two have rear remotes, they will likely be occupied by top-n-tilt. Some guys have 3 rear remotes (ideal). If you have top-n-tilt, and hydraulic angle on your rake, you need to find a place for it by plugging it into 3rd function.
