Testing Fuel Shut off solenoid
11,058
Yes power for ~5 seconds
There will be constant power in, trigger power in, Ground in, and power out.
11,058
T
Thanks again for your help.is there a site I can look up any of this info?
It's in the WSM, AKA service manual, what Tractor / mower / equipment / engine are you working with?
Shad9147
Jan 15, 2023
Hello.shut off worked perfect today.seems both times it's acted up battery had to be charged around same time.maybe something In kill system is draining battery.'95 l3600.
Shad9147
Jan 15, 2023
Hey Journeyman;
Wiring diagram in WMS indicates 15 amp breaker in line t0 timer. I am not clear if that is in addition to the fuse in the fuse box?? I have yet to locate any in-line fuses?? Any ideas where I might look? Wiring diagram also seems to indicate a relationship to the HST foot pedal neutral switch, the PTO switch, and the seat support switch in the circuit to timer and solenoid??? Can use all the help I can get!
Hello.im curious what you found on your bx fuel issue.
