Handyman, that was basically the plan but 2 problems came up. First one, I used a 1" spacer slide over the 17mm shaft on top of the pulley and started drilling a hole thru the spacer and shaft to add a bolt. When I got through the steel spacer my drill bit went no further. It seems the shaft was a hardened steel shaft and my drill bits wouldn't cut it. Now, I could have bought a cobalt drill bit and probably got through the shaft but I would have spent another day without my deck and after testing the pulley the second problem became known. It seems the deck covers fit very close to the top of the pulley which means I had to cut the shaft which also means the 1" spacer had to be removed. Now a new plan had to be made. I could have notched the shaft for a "C" clip but I didn't have a "C" clip so I moved on. Since I have some customers cars coming in to be worked on I had to improvise. So, the plan ended up being a couple of spot welds on the shaft above the pulley and then cut the shaft off as high as I could to give me some room to remove the spot welds and still clear the deck covers. I cranked the welder down to burn in as well as I could but still build up to create sort of a stop for the pulley. Of cource it is a temporary fix till I can get a clip down the road. Heck, I may never have to touch it again....we well see. After all that, I drug the deck back out, hooked it back up and took the tractor away from the house in case it blew up....lol. To my surprise, the deck engaged and it hummed along without a single noise. Of course I had to test it so I mowed my 3 acres at record speed, even the knee high stuff, and never a single noise. Very happy as I have truely missed the 60" deck.
I always like to tell the things I have learned so here it is. First, those bearings are not greaseable and should just be replaced periodically, cheap insurance. Second, that was a terrible idea to cast the shaft into the arm. It needed to be removeable. Third, if it does shear off, use a shaft that is hardened and is hollow. Here is my thoughts on this. If it is hollow, it will cool better and heat build up is what sheared my shaft as one of the bearings seized. Lastly, Kubota wants way to much for that arm. It was real easy to fix and in the end I had $0 dollars in my repair (that's right $0). I got the bearings from my motorcycle mechanic/long time friend (I help him out he helps me out), the shaft also came from him (in his boxes of bolts and pins from tearing down motorcycles), my time is free (right...hehehe) so $0 bucks.
So, my tractor is back in action and my yard is looking good. Now on to buying a box blade and tearing....I mean fixing all the rough spots and weed areas so I can mow all the yard. Thanks for the help.
Josh
