Temperature guage
Hoppy
B7000
Feb 11, 2025
I recently acquired a kubota B7000 and would like to install a temperature gauge and was wondering if there is a threaded spot to mount the sensor. Any help would be greatly appreciated and pictures would be appreciated. Thank you
5,683
FWIW..
maybe something like this will work for you ?
There are several variations( hose sizes and sensor ports).
8,743
You'll need to use the above device put it in the upper radiator hose.
As there is no threaded ports in that system.
DaTow'd
what ever it takes to get the job done
Aug 13, 2013
226
203
Bella Coma BC Canada
I drilled the top of my radiator and soldered in a brass NPT adapter that came with the mechanical gauge works fine
