Telescoping lift arms
minthral
Kubota L47
Nov 22, 2021
194
96
NC
Dang so I called dealer to try get L4060 3PT hitch parts on my L47. It sounds like it will work, however the parts cost nearly 3k! That's just the lower arms, buckles, levers, and telescoping stabilizers...I'd reuse my top and side links.
The telescoping stabilizers are about 250 so might just get that for now.
minthral
Kubota L47
Nov 22, 2021
194
96
NC
Here are all the parts required to get 'Grand L telescoping stabilizers and extending lower links:"
Kubota TD050-39233 COMP. LOWER LINK 1@ $535.14 $535.14
Kubota TD050-39243 COMP. LINK, LOWE 1@ $535.14 $535.14
Kubota TA140-71410 LEVER - MODEL L4 2@ $15.67 each $31.34
Kubota TA140-71400 PIN - MODEL L461 2@ $8.05 each $16.10
Kubota 05122-50645 PIN, JOINT 2@ $1.88 each $3.76
Kubota 05511-50530 PIN 2@ $0.62 each $1.24
Kubota 05511-51615 PIN, SPLIT 2@ $0.42 each $0.84
Kubota 33660-92170 SPRING 2@ $17.55 each $35.10
Kubota TD050-39603 ASSY STABILIZER 2@ $203.82 each $407.64
Kubota TA140-39820 PIN 2@ $9.85 each $19.70
Kubota 04011-50120 WASHER 4@ $0.42 each $1.68
Kubota 05511-50425 PIN 2@ $0.48 each $0.96
Kubota TC050-51200 PIN, SNAP - MODE 4@ $2.09 each $8.36
Kubota TA140-71383 LINK 1@ $194.28 each $194.28
Kubota TA140-71393 LINK 1@ $194.28 each $194.28
Total: $1,985.56 + tax/shipping
This setup should work on all the L series/ Cat 1 hitch, including L47.
minthral
Kubota L47
Nov 22, 2021
194
96
NC
It would be so nice, but I don't think it makes sense to spend 2k on this...
You can get non-Kubota parts from 'eparts'
E-TA140-71383 LH Lower Link End for Kubota $41.85 about $153 cheaper than OEM
E-TA140-71393 RH Lower Link End for Kubota $72.14 about $122 cheaper than OEM
E-TD050-39603 Solid Telescopic Stabilizer for Kubota 2@72.45 $144.90 about $262 cheaper than OEM
Save about $537 total
minthral
Kubota L47
Nov 22, 2021
194
96
NC
I called seller of "E-" parts and they're basically aftermarket clones made in Turkey. They over 50% cheaper than OEM Kubota (also made over seas, mostly in Asian countries), but some of the parts are not in stock, though plan to be made though with no ETA.
So basically aftermarket parts could eventually bring the price down to around $750 maybe.
Grandad4
Apr 5, 2016
442
192
Greensboro, NC
Kub doesn't change the design of its 3 point components very often and Grand L's have come with telescoping links for many years. So something from an older tractor series might fit. Still pricey but probably less than new. They occasionally show up on ebay and you might have luck checking out tractor salvage yards. What condition they might be in is anyone's guess.
